Putting A Shied Up ( Drainage )
Old 09-03-2007, 08:18 AM   #1
SHORTGUN's Avatar
Trade: Concrete
In a few weeks I will be putting a 13' X 15' shied up, but before it goes up I need to put a base of stone for drainage under it. In heavier rains water stands under the old shield. I need to address this problem for this is where the new one is going. It is on a slight slop with a hill behind it, yes it is getting hit by 2 direction so I would like to put a 6 inch base under it.
If you can gave me some advice on how to do this it would be very helpful.
SHORTGUN is offline
Old 09-04-2007, 08:01 PM   #2
tgeb's Avatar
Re: Putting A Shied Up ( Drainage )
If this area is on a slope as you say, could you cut the area level, fill with six inches or so of stone, and bed a perforated pipe in the stone, then trench that pipe to daylight?
That is the approach I would take.
www.gebcon.com
tgeb is offline
Neighbors wall allowing drainage into my yard Team Scream Masonry 20 11-04-2007 02:05 PM
Gravity drainage basement systems skidmark845 Construction 5 08-01-2007 10:22 PM
Drainage pipe from a home onto public sidewalk annelloyd General Discussion 6 04-03-2007 11:54 PM
Drainage pipe from a home onto public sidewalk annelloyd Landscaping 1 04-03-2007 12:23 AM
Putting in for the Moderator A+Carpenter Site Help and Suggestions 11 03-01-2006 02:00 PM
