Pressure Treated Wood Question????
Old 08-29-2008, 08:55 AM   #1
davinci's Avatar
Trade: roofing
i may be getting an addition. should all the plywood on walls be pressure treated, how bout the studs?
thanks
davinci is offline
Old 08-29-2008, 10:46 AM   #2
I used to think so.......
wallmaxx's Avatar
Re: Pressure Treated Wood Question????
Why all PT?
Is it to remain exposed to the elements
without any veneer such as brick, siding or stucco?
PT stuff is typically not kiln dried after treatment...
so when you build with it,
it is wet and can and does twist as it dries.
More project info and someone on the site
can be more helpful.
wallmaxx is online now
Old 08-29-2008, 07:16 PM   #3
davinci's Avatar
Trade: roofing
i guess building a deck would warrant ALL pressure treated wood? how would the wood then be stained?
would the footing postes be pressure treated as well as the joists or just the floor decking?
davinci is offline
Old 08-29-2008, 08:33 PM   #4
concretemasonry's Avatar
Trade: Masonry consultant
The wood exposed to the weather should be pressure treated or naturally resistant (redwood, cedar) to moisture. The amount of treatment or loading depends on whether it is in direct contact of just exposed to the weather.
All treated wood must be connected with the appropriate fasterens (plates, nails, screws) AND all normal wood connected to the treated wood must have the same type of fasteners.
Generally, there is no benefit using treated wood where not required, but there is the potential problems caused later by long term exposure to the chemicals. This is the reason for the changes in the materials used for treatment.
Dick
concretemasonry is online now
Old 08-29-2008, 08:54 PM   #5
Joe Carola's Avatar
Trade: Framing Contractor
thanks
The answer is no. No reason. Did soemone tell you to do this?
Joe Carola
Joe Carola is offline
Old 08-29-2008, 08:56 PM   #6
Joe Carola's Avatar
Yes, building a deck would, but your building an addition, so you don't need any pressure treated studs and plywood.
Joe Carola
Old 08-29-2008, 09:25 PM   #7
wallmaxx's Avatar
thanks
I missed the part about this being a deck.
Old 08-29-2008, 09:33 PM   #8
Are you building an addition now or a deck that may be converted to a 3 season room and then ultimately to a finished addition?
This is a comon aproach, but it requires planning and awareness to codes and the fact that they will change.
My son did the same thing and had to tear out some along the way as the codes changed and enforcement got enforced more.
Dick
Old 08-29-2008, 09:37 PM   #9
genecarp's Avatar
genecarp is offline
Old 08-30-2008, 12:12 AM   #10
davinci's Avatar
Trade: roofing
he also mentioned number 1 pine and number 2 pine??? what the heck are the both of those about?
davinci is offline
Old 08-30-2008, 12:22 AM   #11
BuiltByMAC's Avatar
Trade: Construction
Dude, are you just bored?
Mac
BuiltByMAC is offline
Old 08-30-2008, 12:27 AM   #12
davinci's Avatar
Trade: roofing
why for a deck? number one or two?
davinci is offline
Old 08-30-2008, 07:17 AM   #13
Joe Carola's Avatar
Davinci,
Are you building an addition or deck? Can you answer this?
Joe Carola
Old 08-30-2008, 07:21 AM   #14
AtlanticWBConst's Avatar
Maybe he's been watching too much Holmes on Holmes...
- Build Well -
AtlanticWBConst is offline
Old 08-30-2008, 07:25 AM   #15
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
What in the world is going on here?!?
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 08-30-2008, 09:56 AM   #16
http://www.woodbin.com/ref/wood/softwood_grades.htm
neolitic is offline
Old 08-30-2008, 11:10 AM   #17
Tom R's Avatar
I don't believe pressure-treated wood is even legal in 'living space' (aside from basements), at least here in Jersey.
I'm guessing because in the case of a fire the noxious fumes would kill you even before the smoke or flames.
Tom R is online now
Old 08-30-2008, 11:39 AM   #18
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
You could use marine ply but be pepared to pay. The only time I have ever installed marine was because stone was going over the area where the marine was installed.
Like the others I don't see any point using pt for anything else other than a sole plate that is in contact with concrete. Or for deck building.
JustaFramer is offline
Old 08-30-2008, 12:53 PM   #19
davinci's Avatar
Trade: roofing
you would use ppt for the decking ?
davinci is offline
Old 08-30-2008, 01:00 PM   #20
Restoration Crazy
Are you talking about floor decking for an addition or a deck? We keep asking and your not clearing it up at all
Facebook | Twitter
Wood floors in an elevated bay house (Texas) Monarchy Flooring 22 01-30-2010 12:01 PM
foamboard over wood siding-tyvek too? 72chevy4x4 Windows, Siding and Doors 6 09-17-2007 11:15 PM
Presure Treated Wood and staining???? Sellncars Painting & Finish Work 15 07-16-2006 12:16 PM
Pressure treated or not? Leo G Construction 0 06-27-2006 08:18 PM
trim coil over pressure treated wood?? Lt.H Windows, Siding and Doors 7 04-14-2006 12:12 AM
