Pocket Door In A 6" Wall
Old 03-22-2009, 10:11 PM   #1
72chevy4x4's Avatar
I've installed pocket doors in standard 2x4 walls and noticed they're a bit flimsy. curent project involves a pocket door going into a closet. I'm considering 6" studs for the wall with extra wood on the closet side of the wall for hanging the rods/shelving from. Has anyone tried this?
72chevy4x4 is offline
Old 03-22-2009, 10:36 PM   #2
KemoSabe
loneframer's Avatar
Re: Pocket Door In A 6" Wall
We do pocket doors in 6" walls all the time. I like to use the factory studs and laminate a 1" rip to either side. This way no screws can pierce the stud and scratch the door, which is a common problem with drywallers who speak a different language and come from the rainforest where they lived in grass huts or some s#!t like that.
loneframer is offline
Old 03-22-2009, 10:37 PM   #3
Professional Instigator
rbsremodeling's Avatar
I do probably 10-20 pocket doors in 2x4 walls. It has to be the kit or the building technique you are using.
rbsremodeling is offline
Old 03-22-2009, 11:34 PM   #4
buckeyeso2's Avatar
Trade: carpentry
we only use put pocket doors in 2x4 walls if we absolutely have to. You can't get electrical in these walls. We turn our studs flat in a 2x6 wall, and have had real good success with this method.
Loneframer--you have trouble with drywall screws "piercing" the door even in a 2x6 wall? Those kits are too pricey to use if you don't have to, IMO
buckeyeso2 is offline
Old 03-23-2009, 06:14 AM   #5
KemoSabe
loneframer's Avatar
Not in a 2x6 wall, that's why we went to that setup. I still like to use the kit because the metal wrapped studs keep things nice and straight.
Old 03-23-2009, 11:08 AM   #6
Mike772's Avatar
Trade: Home Builder
When someone says pocket door, I think of the pre-fabbed frame the lumber yard sends that is made of 1x's. Yes, very flimsy in 2x4 walls.
I install many in 2x6 walls. I start with that prefab frame and install it, centered in the r.o. Then I add a layer of 1/2" sound board, for insulation. Then goes a layer of 1/2" plywood. Then drywall.
The result is a very solid and sound deadend pocket door frame. I'm sure there are other methods, but this one works for me.
Mike772 is offline
Old 03-23-2009, 11:52 AM   #7
RED HORSE 554's Avatar
Trade: Project Manager and Builder
This is a tough pocket door Give this a look. far better than a stanley or the others sold at home depot and lowes http://www.kristrack.com/content.php?cat=27
RED HORSE 554 is offline
Old 03-23-2009, 04:36 PM   #8
72chevy4x4's Avatar
thanks for the good ideas. the probelm with the units I've installed in the past, which were box store units with metal tracks filled w/ a 1x2, there was a little too much movement in the wall. I'll report back on my method...going in Wednesday.
Install toilet spaced off wall bob_cntrctr Plumbing 13 01-09-2009 06:53 PM
Brick wall reinforcing Haydin Masonry 6 12-29-2008 09:58 PM
Wall papered brick wall repaint sparehair Painting & Finish Work 1 12-28-2008 08:01 PM
CMU wall repair mcgyverdc Masonry 6 12-04-2008 04:48 PM
