Pissy BITs
Old 12-31-2017, 03:56 AM   #21
Unger.const's Avatar
Rewards Points: 2,412
Re: Pissy BITs
Was at home depot and noticed grk was making shorter screws in the t25 head. As well as a small lag type screw with the t25 .........at least some companies are figuring it out
Unger.const is offline
Old 12-31-2017, 09:23 AM   #22
AustinDB's Avatar
Rewards Points: 464
Re: Pissy BITs
Add 'Spider' bits to this list. Those are used to drive HeadLok screws. Argh!
AustinDB is online now
Old 12-31-2017, 11:48 AM   #23
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,199
Re: Pissy BITs
For me, it is not as much of an issue. We end up losing all of the bits anyways.
That is the real issue. I have proposed that the guys just throw away the previous bit when they change out bits. That way at least I wont spend any time searching for it, only to come up empty.
Easy Gibson
Warren is online now
The Following 2 Users Say Thank You to Warren For This Useful Post:
Bummie (12-31-2017), mrcat (12-31-2017)
Old 12-31-2017, 03:13 PM   #24
Re: Pissy BITs
One of the company reps told me that they designed that lag so that any bit can be used. Philips or square blah blah blah..........so I thought kinda makes sense. Like the socket drivers that can fit multiple styles of bolt heads.
So after I broke the spider bit. I thought oh right most bits should work. Philips........nope........square.......nope...... .t25........f'n liar!
The Following User Says Thank You to Unger.const For This Useful Post:
SmallTownGuy (12-31-2017)
Old 12-31-2017, 04:52 PM   #25
Head sawdust creator
Bummie's Avatar
Trade: Jack of All.... Master of a Couple
Rewards Points: 1,006
Re: Pissy BITs
I hate those multi-bit screw heads!!! Supposed to work for flat head, square head and Phillips head screw drivers. Kinda works for all but not really works very good for any of them!!
"Whether you think you can or think you can't.... you are right!!!" Henry Ford
Bummie is offline
Old 12-31-2017, 06:05 PM   #26
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 7,202
Re: Pissy BITs
One for one. You bring me back a bit, busted or otherwise, you get a fresh one. Otherwise, you come up with the bits.
See how that flies.
Net Zero Energy Is Here Now
ďThe worst day working for yourself, is still better than the best day working for someone else!Ē
..Jim Rohn
SmallTownGuy is online now
Old 12-31-2017, 09:34 PM   #27
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 64
Re: Pissy BITs
Boy that sounds familiar. I'm gonna have to suggest that method to my guys...
Sent from my SM-G900V using Tapatalk
mrcat is online now
Old 01-01-2018, 01:44 AM   #28
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,298
Re: Pissy BITs
I forgot about those stupid spider bits! I bought some of the ledger locks or some similar screw and had a few left over I wanted to use for a quick gate repair. I couldn't find that stupid bit anywhere and they didn't even sell them at HD so I had to buy something different.
SuperiorHIP is offline
Old 01-01-2018, 06:57 AM   #29
Re: Pissy BITs
So you're going to be a repeat customer of spider screws then since it's so easy to deal with?
I'm not a big fan or grk but maybe I am about to since the made most of their screws in T25s
Old 01-01-2018, 11:21 AM   #30
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 10,593
Re: Pissy BITs
Amen, amen. I'm glad I'm not the only one. I now keep an extra drill or two "bitted up" just because of this cr@p.
MarkJames is offline
Unger.const (01-01-2018)
Old 01-01-2018, 01:45 PM   #31
JoshN's Avatar
Trade: Remolding
Rewards Points: 4
Re: Pissy BITs
Why I keep my most used bits in their own slide/extension and I keep a couple free so if I need a random bit I donít use often I donít have to take them out and try to remember where I set them. Cost maybe $20 in slides but itís worth it.
JoshN is offline
The Following User Says Thank You to JoshN For This Useful Post:
Old 01-01-2018, 03:52 PM   #32
Re: Pissy BITs
Great idea. Bit how do you know your grabbing the t20 slide or the t25 slide? Or the t15 slide?.........oh what is the a t30 screw? Ugh!
Old 01-01-2018, 04:47 PM   #33
JoshN's Avatar
Trade: Remolding
Rewards Points: 4
Re: Pissy BITs
I keep a t-25 in the bit holder on the impact. My go to bits are Phillips 2, t-25 flat head and Robertson 2 so I know Iím not grabbing a t-20 or 15 or 27 or 30 because I donít keep those ready. I keep those sizes in my bit case or in case of trim screws in the trim screw case.
JoshN is offline
Let's see how you store drill bits platinumLLC Tools & Equipment 6 11-05-2017 01:50 PM
Bit Holders or Long Bits mobiledynamics Tools & Equipment 57 05-03-2014 03:53 AM
Wiha Terminator Bits TBFGhost Tools & Equipment 35 05-07-2013 06:44 PM
Drill bits Roger05 General Discussion 4 04-09-2013 08:37 PM
Hammer Drill Bits - COO mobiledynamics Tools & Equipment 2 03-22-2013 06:14 PM
