Pissy BITs
Old 12-21-2017, 12:53 AM   #1
Unger.const's Avatar
Rewards Points: 2,672
Pissy BITs
Am I the only one bent out of shape about bits for screws?
For many years I've used boatloads of two types of screws. The left a T25 torx gen purpose ceramic coated. And right is powerhead screws #2 square drive. (The only Philips drives I've bought was for the collated drywall gun). I always have 3 bits in my pocket to always be ready ph#2 sq#2 and T25.
Now. My favorite screw the powerhead screw changed it to T20. When one of my suppliers told me of the change. Said he still had some sq#2 in stock I got what they had. I voiced my gripe.......he said I'm not alone lots of others are hot under the collar. Later I forgot and grabbed a bunch of boxes at woodcraft only looking at length. Went to use a few......curse alot. Now I find that they had one of those new coke flavor oh wait now coke classic moments. But they only do a few lengths in square drive. Everything else T20.
Philips bits........meh.
Robersons bits.......Ok ish.
Torxs 25........awesome!
Torxs 20..........why the pain?
Torxs 15.............Now you're silly.
Torxs 10...........you just designed a cam out drill bit for screws!
Anyone else wish they would make T25s the standard?
Unger.const is offline
Old 12-21-2017, 05:55 AM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,454
Re: Pissy BITs
You think that's bad Hilti likes to use a mix of T-25 and T-27....Like C'mon just use T25 for both!
That's the problem for Torx, too many sizes.
Then you get into propriety BS like "SpiderDrive".
Inner10 is online now
SmallTownGuy (12-21-2017)
Old 12-21-2017, 06:11 AM   #3
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,412
Re: Pissy BITs
I wouldn't have even clicked on this to read, but I thought the title was "Pussy BITS"
Home Designer Series Software
B.Johnson is offline
The Following User Says Thank You to B.Johnson For This Useful Post:
Fouthgeneration (01-05-2018)
Old 12-21-2017, 06:58 AM   #4
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,386
Re: Pissy BITs
I like the square. Fastcap cabinet screws were the same. Then they changed them to the T20. Now I have to buy an extra pack of bits with the screws.
Big Johnson is offline
Unger.const (12-21-2017)
Old 12-21-2017, 11:45 AM   #5
Re: Pissy BITs
Powerhead screws are fastcap cabinet screws. I use them for way more then cabinets. Great product till now.
I just wanna know am I off my rocker? If someone produced their whole line up with T25 would you gravitate to be brand loyal there? (Except trim head screws)
Old 12-21-2017, 11:57 AM   #6
Re: Pissy BITs
And do you go ahead and use the t25 to run in or out the t27? They sorta work. Till they cam out then your like "oh well" sucks for anyone that has to take that screw out.
It's like half the door hinges in older homes are cammed out. Home owner........I tried to tighten it with my drill! (Shows me drill). Me........well you have a #1philips (or #3) bit in your drill. You need a #2. Homeowner.........there is different sizes of Philips?
The Following User Says Thank You to Unger.const For This Useful Post:
Bummie (12-31-2017)
Old 12-21-2017, 11:59 AM   #7
Re: Pissy BITs
That explains why there was 300 views of this thread overnight but only 3 comments. We are here to build things with wood..............oh nevermind my mind went there too.
Old 12-21-2017, 09:04 PM   #8
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,424
Re: Pissy BITs
Agreed...I absolutely love and use GRK screws for a lot of things...but...
Trim Screws T15
Cabinet Screws & Small R9's T20
R9's & small RSS T25
Caliburn T30/T40
It does get to be a bit much...I've gotten good with their color coded system, most of the guys ask for "Green Bits" or "Gold Bits" or "Red Bits" now instead of calling them what they are...If everything were the green T25's I'd be thrilled...ok, keep the trim screws tiny, but make them less likely to strip out because they're a pain if they do!
mstrat is online now
The Following User Says Thank You to mstrat For This Useful Post:
Unger.const (12-22-2017)
Old 12-21-2017, 10:21 PM   #9
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,346
Re: Pissy BITs
For me it was first the mixing deck bits and phillips, then it was mixing deck bits and T25 deck bits, then it was mixing up the t20 and t25 if I had smaller than 3" screws and 3" and larger. FINALLY they wised up and made them all t25 and for a year or two I was set. NOW I have found myself using a lot of the grk screws which use t15 and t10. Make all the damn screws t25 except trim heads which would work for all from 1.5" to 5" if they use t15.
Seemed like a petty complaint so I have always kept it to myself, glad to see there are others as grumpy as I am about it.
SuperiorHIP is offline
The Following 4 Users Say Thank You to SuperiorHIP For This Useful Post:
Artworks (01-01-2018), MarkJames (01-01-2018), SouthonBeach (12-22-2017), Unger.const (12-22-2017)
Old 12-21-2017, 11:30 PM   #10
Mordekyle's Avatar
Rewards Points: 3,296
Re: Pissy BITs
Trim Screws T15
Caliburn T30/T40
That's me right there. I don't even know the numbers.
I used to use a lot of composite deck screws that take purple bits. Now I use the green bit for deck screws. I use the gold bit for trim screws, and I sometimes use the red bit to install vinyl windows. Headloks take the spider bit.
Mordekyle is online now
Old 12-22-2017, 01:47 AM   #11
VinylHanger's Avatar
Rewards Points: 7,554
Re: Pissy BITs
Maybe we should just go back to slotted screws, ya buncha babies.
I don't mind T-20s.
VinylHanger is offline
Old 12-22-2017, 05:51 AM   #12
B.Johnson's Avatar
Trade: Builder
Re: Pissy BITs
heavy_d (12-31-2017)
Old 12-22-2017, 06:30 AM   #13
Re: Pissy BITs
Iíll pass.
Old 12-22-2017, 06:37 AM   #14
PaulFalls44's Avatar
Trade: Electrical
Rewards Points: 42
Re: Pissy BITs
Haha I did the same thing!!
PaulFalls44 is offline
The Following User Says Thank You to PaulFalls44 For This Useful Post:
Unger.const (12-24-2017)
Old 12-22-2017, 06:39 AM   #15
Inner10's Avatar
Re: Pissy BITs
I have, and it drives them but its wobbly as all hell.
Old 12-22-2017, 08:37 AM   #16
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,840
Re: Pissy BITs
"Pissy BITs" - and Hissy Fits!
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 12-24-2017, 12:51 PM   #17
Re: Pissy BITs
I don't mind T-20s.
Says the guy who runs in t25 screws with the t20 bit.........meh.......it worked........lol
VinylHanger (12-25-2017)
Old 12-24-2017, 12:54 PM   #18
Re: Pissy BITs
Let me get the nerf gun out of the truck and we will install that siding in no time ma'am.
Old 12-24-2017, 03:04 PM   #19
JoshN's Avatar
Trade: Remolding
Rewards Points: 4
Re: Pissy BITs
I was helping some friends do a sub floor and the store we went, the 2 inch construction screws were T-20 and horrible to start and the 3 inch ones were T-25 and no problem to start. Took us forever using the 2 inch screws because they didnít want to start. Ended up going to home depo and buying a pack of grip rite construction screws to make my life easier even if it cost me a few dollars. Sped up the process ten fold. Plus I didnít have any T-20 bits on me so we had to go buy some becuase the box came with one bit and there were 3 of us screwing down the floor.
JoshN is offline
Old 12-24-2017, 03:24 PM   #20
pizalm's Avatar
Rewards Points: 744
Re: Pissy BITs
Trim Screws T15
Caliburn T30/T40
We got a bunch of the trim screws this spring, the first batch was t15. Then the second were t10. The exact same screws. So frustrating.
Sent from my iPad using Tapatalk
pizalm is online now
Let's see how you store drill bits platinumLLC Tools & Equipment 6 11-05-2017 12:50 PM
Bit Holders or Long Bits mobiledynamics Tools & Equipment 57 05-03-2014 02:53 AM
Wiha Terminator Bits TBFGhost Tools & Equipment 35 05-07-2013 05:44 PM
Drill bits Roger05 General Discussion 4 04-09-2013 07:37 PM
Hammer Drill Bits - COO mobiledynamics Tools & Equipment 2 03-22-2013 05:14 PM
