Number Of King Studs?
I'm a wood floor guy but like most blue collar I dyi in my own home.
I just ro a wall for a bay window that is 5' 10" wide. How many king studs are required for a bay window that size? I installed one king stud on each side, two trimmer studs on each side, and six jack and cripple studs on the top and bottom. There are regular wall/king studs 5" to the right and 10" to the left of the r.o. window king studs. Do I need a second king on either side? I'd rather not put them in if I don't have to b/c now it would involve moving a bunch of electrical work around. Thanks |
Re: Number Of King Studs?
Six jack studs? Where did you put them?
#3 | |
Re: Number Of King Studs?Quote:
Anyway ...........about my king stud question??? |
Custom Builder
No second king needed. What your calling trimers, we call jacks. A king and a jack together make a trimer, but you hit the cripples right, if they are short studs under the window.
Bob
Bob |
Kings go from the top plate to the bottom plate.
Jacks go from the bottom plate to the header. Trimmers go from the sill to the header. Cripples fill the gaps between the top plate and the header or the sill and the bottom plate. |
#6 | |
So lemme get this correct b/c when you surf the web I find all kinds of names for the same framing piece. Kings: Full stud from top plate to bottom plate Header: Horizontal double 2x? piece above window Jacks: Supporting header nailed to King Trimmer: King and Jack nailed together Sill: Double plate directly under window Cripple: Shorties above header and below sill Is that right? edit:wow teetorbilt that was identical timing |
I also don't believe that this works in Maine, they have a different name for everything.
#8 | |
I just ran cripples under the sill attatched to the jacks The sill was fastened to the jacks first by nailing though the jacks horizontally and into the sill. Is this acceptable? Oh yeah ...do you agree with Glasshouse on my king stud question? |
Custom Builder
I've heard people call an extra 2x in the opening a trimer before Teetor, but for as long as I can remember just about everyone else I've worked with has called the king/jack paired as a trimer.
Point counter point: I saw Dean Johnson and Joan Leabler (Hometime) use your trimer reference. Sill will be fine nailed like that. And yes Teetor agrees with me on the single king........RIGHT TEETOR......don't make me get postal. Bob
Bob |
It sounds good to me. I usually nail the cripples to the jacks and nail the sill straight down. You did put cripples under each end of the sill.....right?
Bob, how much snow would you have to run through to get to me? I ain't skeered. |
#11 | |
Thanks, one king it is |
Trade: Builder/Remodeler
Yeah! Sounds fine. However that header may need to be a Lam? Load bearing wall? Snow loads? Clear span 5'10"?
Ipson, I was kind of thinking along those lines as well. A pair of 2X6's or 8's will make the span but I would like to see the trimmers added to give the header more support.
Custom Builder
Why is every one now a days so lam happy, ....is the shepard away?
Bob
Bob |
Teetor,
Up here Dbl. 2X12 would be questionable with just roof load and not to mention a second floor load? 2x6? Break that over may knee! |
Just checked the permissible working stresses for structural timbers from government tests, bending, PSI, allowable stress in extreme fiber, dry location, sound S yellow pine. It checks in at 1,300. Doug fir at 1600.
Teetor,
That is only partly to do with all the factors involved! What about shear or the overall span thats riding on that header! floor loads, snow loads? We use alot of Lam beams around this area. Not to say it will not work some where else. I have two clac programs for beams and joist that work very nicely, but you have to put in all the conditions involved to have a solution! I'm saying you have more of the solution than I! |
#18 |
I am aware of all of the loads involved, where I live we have upload and interior pressure loads as well (hurricanes). To bring this back down to reality, we are talking of less than a 6' opening, less than a pair of 36" french doors. All of the construction that I have been involved with will accept this without a full fledged engineering assesment.
I use Catia V5R14 and you are correct in that you have to plug in ALL of the numbers which we don't have. Finite Element Analaysis will also predict point, type and severity of failure. In theory, I can push a house through Mach 3 although I doubt that it would make it anywhere near that. Back to reality, it's less than 6'. If there is a second story, I feel even better about it. |
#19 |
Teetor,
You may have uplift and wind issues, we deal more with shear. The calc programs I'm talking about are supplied by the manufactures such a Boise and Roseburg. That spec Lams and TrussJoist and such. Just felt your specing out something thats to lite not knowing all the values of the case load. Q. You don't have up lift if the wind not blowing, unless there's another reaction point thats causing it? Hey you win! I need My sleep! Sleepless in Michigan. |
| USDOT Number | Speedy Petey | Vehicles | 18 | 07-24-2011 11:38 PM |
| cutting steel studs | 25BRIAN | General Discussion | 28 | 05-22-2009 09:41 AM |
| Steel Studs in Bulkhead | DSB_Const | Framing | 3 | 04-02-2009 03:12 PM |
| Fingerjointed Studs | Milhaus | Green Building | 20 | 05-18-2007 11:12 AM |
| Metal Studs Vs. Wood Studs | Towatei & Co. | Drywall | 7 | 05-12-2007 11:03 PM |
