Need Some Advise On An Addition
Old 07-22-2007, 02:41 PM   #1
mattp's Avatar
Trade: roofing
I'm putting an addition on a ranch house 24'x80'. The addition will gable back in to the house ( so the house will look like a T from the sky. The addition was suppose to be 24'x24' on a 5/12 to match the house. I get thier Monday to lay it out and the HO has talked with the lumberyard and deciedes to go 30' wide on a 4/12 pitch. I know it will still work but how will it work and how would you frame a cathedral ceiling in it. What would I use for my ridge beam it needs to be 24' long and will my rafters be putting to much pressure on my outside walls.
mattp is offline
Old 07-22-2007, 04:17 PM   #2
smitty58's Avatar
Trade: carpenter
Re: Need Some Advise On An Addition
Just use scissor trusses. Then you will only need a ridge from the existing roof to the first truss. Then build your valley with rafters.
Are you building this addition? It sounds like you need to sub out the framing.
smitty58 is offline
Old 07-22-2007, 04:22 PM   #3
mattp's Avatar
Trade: roofing
Thanks smitty, The reason I wanted to stay away from trusses is 1. with a 4/12 pitch I didn't think that would give me much pitch on the iside. 2. I will have to cut my rafter birdsmouth deeper in the additio so the fascia meets up (prob. can still be done a trusses)
mattp is offline
Old 07-22-2007, 06:41 PM   #4
Thom
thom's Avatar
Hmmm, seems to be an echo in here.
thom is online now
Need some advise on an addition mattp Carpentry 5 08-05-2007 07:30 PM
Advice with room addition and blueprints A.W.Davis Remodeling 35 03-28-2007 07:32 PM
Question on addition rikanit Construction 5 02-11-2007 01:16 PM
New painter in need of some advise Cramerica80 Painting & Finish Work 14 10-14-2006 09:52 AM
Addition Full Basement sady Specialty Trades Picture Post 4 12-29-2005 09:51 PM
