Trade: roofing & Painting
Need One Hour Firewall On Detached Garage.
Im building a detached garage that is within 5 ft from the property line & code requires a one hour firewall. What is the easiest way to get the firewall built.
Re: Need One Hour Firewall On Detached Garage.
5/8" Type X gypsum on one side will do.
I'm a Mac
Trade: ICF Construction
I did this in Toronto once and was given the option of also either using brick or aluminum siding. That was above and beyond the 5/8 drywall
Chris |
Trade: Consultant
Depends- are they requiring you to acheive the 1-hour rating from either side of the wall, or just from the inside? If it's the inside only, you can just use 5/8" Type X rock- if you need to be rated from both sides, you'll need a 2-sided assembly (like putting 5/8" rock under the siding).
If your over 5 ft you need protection from the inside if your with in 5 ft you need protection on both sides. You are not allowed any openings like windows or doors under 5 ft. To achieve the rating you can layer material to total the 1 hour. A 2x4 has a 20 min rating ,5/8" rock has 20 min, now you have 40 min add another you get an hour from that side. You can use therma fiber insulation can add 15 min and fire resistant sheathing with 5/8" Type x (which is 40min) inside there are many ways to accomplish it. The wall itself needs to be protected.
If it's 5' or less we can make our 1 hour with
5/8" type X inside, and 5/8" of this http://www.gp.com/build/product.aspx?pid=4674 on the outside. No windows and only rated doors on that wall.
| Firewall options in crawspace instead of concrete footer/stemwall? | kdub1777 | Carpentry | 4 | 08-19-2008 04:58 PM |
| New detached garage sub panel | Magnettica | Electrical Picture Post | 17 | 08-10-2008 09:52 PM |
| Help - Garage floor/room addition | drbrsjr | General Discussion | 10 | 04-26-2008 09:36 PM |
| 200 amp service to detached garage (followup) | CR295 | Electrical | 0 | 09-19-2006 01:46 PM |
| Flat roof over garage leaking under exterior walk out door | IHI | Roofing | 18 | 05-30-2006 10:28 PM |
