Need Help On A Window Install Estimate
Old 03-06-2007, 02:46 AM   #1
bkn4x4's Avatar
Trade: GENERAL
Had A Job Drop In My Lap ,that I Normally Dont Deal With. It Is A Window Replacement Job.
What I Need To Know Basicly Is : How I Should Estimate The Job . What Rate I Should Charge ? Im In Ca. .......
The Job Is Pretty Basic, They Are Millgard Windows New Frame. Just Have Trim To Remove To Replace Them.
Just Need A Base To Use For My Calculations
Thank You
bkn4x4 is offline
Old 03-11-2007, 04:23 AM   #2
y0manda's Avatar
Re: Need Help On A Window Install Estimate
Just like anything else you need to look at all the factors. What type of old windows are you removing? are they just normal aluminum sliding windows? or steel casements?, wood Double hungs?. Are the windows you are installing new construction or retrofit? Is this a single/2 story home? there are a lot of info missing for anyone to actually help give you a fair price on which to bid the job accordingly. If you have any questions you can PM me. I have installed windows & Doors everyday for 8 years.
y0manda is offline
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Need Help On A Window Install Estimate bkn4x4 Carpentry 22 10-14-2007 11:37 PM
Need Help On A Window Install Estimate bkn4x4 Windows, Siding and Doors 17 05-23-2007 04:16 PM
window install in block EDENSCAPES@DNET Carpentry 12 03-13-2006 08:41 AM
Just need to customer vent IHI General Discussion 8 11-08-2005 09:52 PM
