Trade: roofing
Need Help On Finishing Roof For My Deck
done with my deck, now I need to add a shed roof. max pitch is going to be 3/12. I want to do a shed roof. don't know where to start next. do I put a bottom plate on the the deck, then my 4x4 posts, then 2x4 plate on top. do I double top plate and then put a 2x8 beam. need some help.
I am unable to attach a picture, the file is to big. |
Trade: trim carpentry
Re: Need Help On Finishing Roof For My Deck
hire a carpenter
| The Following 2 Users Say Thank You to mmike032 For This Useful Post: | knucklehead (07-08-2009), wallmaxx (07-09-2009) |
Alright everyone...move along...nothing to see here...
Just buy a prebuilt roof and have it delivered, a few toe nails and your good to go!
Dave |
I like Green things
Get an RV awning. Or a carpenter, or a clue. Your choice.
Trailer park boy
"Industry without art is brutality"
| The Following 3 Users Say Thank You to shanekw1 For This Useful Post: |
#7 | |
Home Depot aisle walker
Trade: home remodeling
Re: Need Help On Finishing Roof For My DeckQuote:
Eater of sins.
Trade: Designer/Drafter Extrordinaire
No you don't need any of that stuff, just find yourself an old garage door of the proper size.
Take the one from your neighbor if it looks like it will fit. Then, attach one end to the existing roof and the other end (the one with the metal rod extending form end to end) prop that on two 2 x 4s. Slope it down toward the 2 xs and then tighten the metal rod to straighten it up nicely. This works great and is quite inexpensive. I hope this is a help. Andy. |
| The Following User Says Thank You to ScipioAfricanus For This Useful Post: | greg24k (07-09-2009) |
Re: Need Help On Finishing Roof For My Deck |
#10 | |
Trade: Framing,Remodeling,General Contractor
#11 | |
Good ideal |
woodchuck2
Well first off, i hope i am not out of line here, the 3-12 pitch isnt alot so i would go with PT 8"X8"s for you supports. You should use a TJI layed on its side for the top plate. Then you want to fill the void of the TJI with LVL's for you top beam. For you rafters i would use TJI's 6"OC to carry any kind of snow load. Now with proper clamping and use of glue you wont need any screws or lags, you would want to just tack everything together until the glue sets. For tieing into the main roof just fire up a saw and cut holes in the roof to allow the TJI's to slip inside but you want to use alot of caulk to prevent any leaks. What are doing for the shingles or tin? I would place tin sideways so any water runoff from the main roof would slow down on the shed, er i mean deck roof or else the water runoff will shoot right off the roof. I hope i have been of some help, lets be safe.
With this system you could also use the roof for a sluice box in case you ever got into placer mining so be sure to put the whole roof on pivots.
woodchuck2
I dont know about you but with my luck this guy would hit it big and forget all about us and how we helped him
Trade: contractor
I'm curious ...who helped you build the deck?
#16 | |
Trade: framer
You came to the right place. In a cost saving effort, which yours clearly is, pitch it back towards the house. This way you'll save on excess gutter cost.
What would you say...ya do here? |
| Bison deck supports for roof deck | Chris G | Decks & Fencing | 20 | 11-17-2010 05:36 PM |
| Deck over a tar and gravel roof | yipee | General Discussion | 2 | 06-02-2008 10:30 PM |
| Patching penetrations in concrete roof deck | geecee | Concrete & Paving | 1 | 03-04-2008 03:34 PM |
| Need help designing Roof for addition | jaymay75 | Framing | 21 | 06-17-2006 10:47 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
