GENERAL CONTRACTOR
Trade: I am a Licensed Contractor in Tennessee
Mono Slab Question?
Job calls for a 30 x 49 mono slab. It will have 12" deep footers 2' wide around perimeter with rebar etc... My Question this the slab will have a metal building on it 30 x 50 with slab on the end outside area attached making the total length 62 ft. should I pour this extension of 30 x 12 as a separate pour or will it break off if i try to go from a monoslab into a 4 inch to 6 inch pad? Thanks for your replies and I know all you concrete experts will give good advice.
Re: Mono Slab Question?
I would not pour the approach slab with the main building slab. I am a little confused by the description, but most steel buildings have specific details, like a sheet ledge and anchor bolts set on specific points, as well as door trays, etc. Since the building covers the main slab, and the driveway or approach pad would be lower then the main slab by 2 inches, it would be a pain to form the sheet ledge and door trays on a mono pour. Another factor would be the heating and cooling of the outside slab compared to the building slab....and you would cut a control joint anyway...just make it easy on yourself and make 2 pours.
I would pull rebar pins out of the form to tie the outside slab to the main floor.
unlicensed hack
Trade: wood butcher
Agreed.... Do it in seperate pours with rebar pins in the main slab to tie in the outside slab.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread. |
| built up slab question | stampcrete | Concrete & Paving | 9 | 03-27-2008 05:24 PM |
| Demo a foundation under a radiant heat slab without disturbing the slab...? | wackman | Remodeling | 18 | 04-02-2007 12:38 AM |
| foundation question | Scott Young | General Discussion | 4 | 03-04-2007 10:56 PM |
| Basement slab question | n74tg | Masonry | 5 | 05-26-2006 04:38 PM |
