Mold In Basement
Old 04-15-2007, 08:56 AM   #1
wayne3434's Avatar
Trade: carpenter/remodeling
Mold In Basement
whats the best way to treat this problem i ve never had to deal with this before?
wayne3434 is offline
Old 04-15-2007, 12:19 PM   #2
CO2Solutions's Avatar
Trade: Dry Ice Blasting
Re: Mold In Basement
Where is the mold located/ (i.e. concrete, dry wall, framing etc.) There are many ways to have mold removed, the most common is chemical spraying and scrubbing. I do some mold remediation and I do it by Dry Ice Blasting, it's becoming the quickest most effective way to do it. Mold is killed instantly...it's typically a little more expensive but you can be sure the mold is killed and have piece of mind. Firstly, you need to find out why/where the mold is coming from and eliminate the problem then have a Mold Remediator in.
Good luck,
CO2Solutions is offline
Old 04-15-2007, 01:39 PM   #3
Tonkadad's Avatar
http://www.ncsu.edu/ehs/www99/right/...emediation.htm
Tonkadad is offline
Old 04-15-2007, 06:14 PM   #4
wayne3434's Avatar
mold is in basement on floor
Basement Mold Milhaus Construction 7 02-15-2007 01:54 AM
New Construction Showing Mold... thepawnshop Construction 13 10-20-2006 07:43 PM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
When you find mold?? theworx General Discussion 2 03-05-2006 03:15 PM
