Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction
Old 07-06-2009, 07:29 PM   #1
moisture on tile floor in summer
HO asks for a solution to problem-during the summer months, the tile floor in the kitchen/dining rm and foyer gets condensation on it (from front of foyer to kitchen approx 28' away) during the summer with AC running full time (no set back).
the tile is likely directly adhered to the concrete slab. there IS high water issues on the lot and drainage has been an issue in the back yard of the house.
My thougts are that the slab is drawing moisture up into the space and that's the cause of condensation on the tile during AC use. Is this correct/possible?
72chevy4x4 is offline   Reply With Quote
Old 07-06-2009, 07:46 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Professional Sawdust Producer
Sounds like your high water table may be the problem. Use a silicon water sealer on the tile and grout. Very temporary though. Fix the high water with drainage around the house and there is a good chance it will go away.
Measure Twice Cut Once -- It's a lot easier to cut more off then it is to cut MORON.
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline   Reply With Quote
Old 08-31-2009, 05:11 PM   #3
Trade: Insurance Restoration
Have you solved this problem yet?
Due to the water surrounding the slab, it sounds like excessive vapor emission rising through the slab.
While the specs vary now, the average amount of vapor pressure that should exist before causing significant damage is 3-3.5 lbs. of vapor pressure per 1000 sf per 24 hours.
I call water a "funny animal". Water travels the path of least resistance. In this case, there is mostly likely an excessive amount of vapor pressure, 5 lbs., trying to escape the surface. First, the vapor will egress through the grout lines. In the mean time, the excessive pressure is weakening the integrity of the thin set and tile. The tile will eventually become hollow and or buckle or crack.
There are methods to check and solve. Yet, first the water outside needs to be redirected.
Let me know if you need more info.
Insuranceclaims is offline   Reply With Quote
Old 09-01-2009, 08:06 PM   #4
I would be interested in more info. I'm still waiting on the HO to make decisions about the remodeling job...nothing else was done about the condensation on the tile. wonder if it could be impacted by an improperly sized AC unit?
Old 09-01-2009, 11:09 PM   #5
Sounds to me like no vapor barrier,
or at least a compromised one.
neolitic is online now   Reply With Quote
Old 09-02-2009, 01:39 AM   #6
What city is the job in? I am in Florida, but maybe I can locate someone in the area who can help. It is possible to get preliminary readings of moisture content under the tile with the use of a Tramex MoistureConcrete Moisture Encounter 4. Other tests can determine temperature and humidity of the concrete under ASTM-2170 and calcium chloride test.
Yet, for these tests, there needs to be several areas of clean slab.
Anyway, again, what city is the job in? I will check tomorrow.
Old 09-02-2009, 06:24 PM   #7
Trade: Contractor Residential Construction
Dew point
Some research:
http://www.thefloorpro.com/community...ting-tile.html
http://www.proconweb.com/pdfs/public...11_30_2007.pdf
I like the dew point angle. Cold air + warm = moisture. Any problems with the windows. See any moisture around them? What about the mill work around the windows? Signs of staining?
10fingers is offline   Reply With Quote
Tile over Tile fireguy Flooring 3 02-26-2009 11:36 PM
Moisture Moisture Moisture... fixitpete Flooring 22 12-30-2008 04:13 AM
Crawl Space Ventilation Ed the Roofer Roofing 2 11-27-2008 11:15 AM
Tile on GP Mold and moisture resistant sheetrock Bill Drywall 3 03-27-2008 08:27 PM
Tenwolde's 5 Myths Of Moisture Ed the Roofer Roofing 3 02-10-2008 03:37 PM
