Material To Cover Inside Of Horse Trailer
Old 07-12-2006, 07:00 PM   #1
arnheimacres's Avatar
Trade: Home construction
I am in the process of building a camper inside the front part of a new horse trailer. I have fitted 1 inch styrofoam between all the bracing and am ready to cover it (wall covering). The front of the trailer has a rounded surface. Any advice out there as to what material could be used that is flexible enough cover these surfaces? Thanks.
arnheimacres is offline
Old 07-12-2006, 07:05 PM   #2
Remodeler
MinConst's Avatar
Re: Material To Cover Inside Of Horse Trailer
You could use paneling. It should bend enough to conform to the curve. Or a fabric would also be nice for a camper. If you use fabric start at the top center and stretch the center working out top and bottom.
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 07-12-2006, 07:36 PM   #3
We have considered and rejected the idea of fabric. I'm not sure that paneling will work because the surface is rounded (like the inside of a ball). I'm sure paneling would probably work if it were like a normal curved wall though. Thanks for your input - any other ideas out there?
Old 07-12-2006, 08:07 PM   #4
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
Frame it off to a square edge and keep access to the radius part by way of door to use as storage. Cover the framing with some plywood then Laminate it your favorite color.
Eric K is offline
Old 08-28-2006, 08:00 PM   #5
Just 'Finishing' Up...
erik edlund's Avatar
Arnheimacres,
Have you considered basic countertop laminate material for ALL surfaces? MANY style choices, very flexible (er, up to a point...). You may even be able to find shorts and remnants (mix-n-match your panels, for instance) for a discount if you hunt around at distributors/ manufacturers. And, you can score it and pop it, like drywall (umm, MOST times...). Elsewise, just use a trim saw.
Kind regards,
Erik D. Edlund
erik edlund is offline
Old 08-28-2006, 08:25 PM   #6
My custom title
Brushslingers's Avatar
1/4 inch sheetrock will bend to whatever you want if mopped down... IE get a mop and soak it. I've built photo studios in this manner.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 08-28-2006, 08:49 PM   #7
North Country's Avatar
Trade: Log-Style Home Contractor, Custom Homes,Remodeling, Stone
FRP panel, flexible and washable.
North Country is offline
Old 08-31-2006, 10:26 AM   #8
Plays Well With Numbers
Debookkeeper's Avatar
Trade: Bookkeeper for GC, Residential Const, HVAC & Plumber
My Husband is a trailer mechanic and he said to use kemlite FRP. You should be able to get it at your local truck supplier. He said they sell all different kinds of moldings and what not.
http://www.kemlite.com/newindex.asp?Parm=transportation
Debookkeeper is offline
Trailer: Customizing ideas needed. Long Robie Vehicles 195 11-06-2011 11:32 AM
Let's discuss the van trailer thing again JPV123 Vehicles 21 12-23-2009 02:07 AM
Material choice for fascia. kclapper Windows, Siding and Doors 5 07-31-2007 11:14 PM
to all enclosed trailer owners Starboyz66ftp Vehicles 6 04-30-2006 12:16 AM
new here ApgarNJ Vehicles 3 04-17-2006 06:11 AM
