WORKING HARD
Trade: GENERAL CONTRACTING, ELECTRICAL
Load Bearing Wall
I have a wall that I would like to use as a load bearing wall. This wall will not only carry the weight of the floor above it, but also a knee wall for the roof. I am wondering if I may have a problem with this because the wall is off set approximately 18 inches from the girder and piers below. Can someone tell me if this is close enough to use this wall to carry the load or if the wall absolutely needs to be directly over the girder and piers. Thanks in advance for any help.
Re: Load Bearing Wall
Yeah, someone can. That someone's name is your engineer. There's not nearly enough information given so far to even guess. Engineers are worth their weight in gold on stuff like this, and they're not nearly as expensive as one might think. About the only way you're probably going to pass inspection is with an engineer sealed detail on that anyhow.
You are an experienced GC?
me or slave driver?
You know who I meant Marc.
to many variables to answer without seeing. in general, stacking is good.
Trade: Squirrel Handler
You are an experienced smart-ass?
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
| Load bearing wall or not??? | BMAN | Remodeling | 26 | 07-28-2008 07:16 PM |
| Identifying load bearing wall | 1stchoice | Framing | 25 | 05-12-2008 06:27 PM |
| removing a none load bearing wall?? | samiam | Framing | 7 | 09-12-2007 08:33 AM |
| Load Bearing Wall | tsicby | Framing | 5 | 08-22-2007 08:58 PM |
