Levelling Interior Sloped Concrete Floor
Old 05-30-2007, 04:02 AM   #1
reveivl's Avatar
Trade: Renovations
Got a customer with a 17'x 14' bedroom that was presumably once a concrete carport or patio. Anyhow, it has about a 4" slope in the 17' direction. She wants it levelled and I'm thinking of cutting wedges out of 2x6 and attaching them to the concrete. Then sub and finish.
Question is, how to attach?
Ramset the thin end and nail the thick end to the walls and let the rest float? Ramset 1x4 across and toe-nail the wedges?
Glue? Bolts? Brackets? Hopes? Dreams? Cleared Checks?
Interested in all comments regarding this.
reveivl is offline
Old 05-30-2007, 09:41 AM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Levelling Interior Sloped Concrete Floor
I was going to suggest self leveling floor leveller, you need a little more than a lot to do that. Anyways, I would use you 2x6 (P.T.) and scribe/rip it down, use cut pieces and fasten them (Tapcons are fine) on there flat to the existing floor and attach your new levelled wood to it. As a suggestion, before placing down the sub-floor fill the void with EPS to keep the toes a little warmer.
Chris
Chris Johnson is offline
Old 05-30-2007, 10:45 AM   #3
boman47k's Avatar
Higher tham normal ceiling?
boman47k is offline
Old 05-30-2007, 10:57 AM   #4
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Was it originally sloped for drainage?
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 05-30-2007, 12:40 PM   #5
reveivl's Avatar
Trade: Renovations
Unfortunately the ceiling is NOT high, so I'm concerned with raising the floor too much. Want to keep it as low profile as possible.
Don't know what the space was originally, could have been a car port, though it's in a strange place relative to the house for that, or a patio, sloped for drainage.
reveivl is offline
Old 06-09-2007, 05:01 PM   #6
MFWIC
Tmrrptr's Avatar
Trade: house painter
Is there a reason you don't float it out with lightweight concrete?
Seen it done 2nd story commercial for sound/fireproofing.
Neato!
r
Tmrrptr is offline
Old 06-09-2007, 09:53 PM   #7
reveivl's Avatar
Trade: Renovations
Thanks for the input, everyone...did that part of the job. Scribed wedges to the concrete, attached them to the walls where I could, ramset them down where they were thin enough and ramset cleats beside them where they were too thick for a nail to penetrate the conc. Put 5/8 t&g over them, glued it and nailed where I could, ramset where the wedges were too thin. Lot of shots. Voila, flat level floor ready for engineered floater.
reveivl is offline
Old 06-09-2007, 09:58 PM   #8
boman47k's Avatar
Heheh, you replied while I was typing. Glad to see you got it. I was thinking allong the lines of what Chris said with maybe some construction adhesive.
boman47k is offline
Ceramic tile over concrete floor Handyman62010 Flooring 14 03-15-2007 09:40 PM
Checkered floor on concrete Barry M Flooring 9 10-24-2006 08:36 PM
Newly placed Uneven concrete floor fix?? warrenc Flooring 3 09-26-2006 02:28 AM
Hardwood floor on concrete basement? georgia dawg Flooring 5 07-13-2006 12:14 PM
Concrete floor in a pole barn thinkncabin Masonry 3 03-31-2006 06:45 PM
