Recovering IT Guy
Trade: Handyman, Home Improvement, Kitchen & Bath Remodeling
Lally Column Footer Depth
I'll be adding Lally columns to a house which has existing brick columns about every 10 feet. It's a small 2 story house about 80 years old. The floor has sagged some at the middle of the span and the homeowner wants steel columns with concrete footers.
The beam is a stack of (2) 2x8's laid flat so the depth of the beam is only 4". That would certainly explain the sag! This is in Rhode Island where it gets a little cold from time to time, but the column will go in a full basement and the basement floor is 5 feet below ground so frostline is probably not an issue. Could someone tell me what diameter / depth the column footers should be?
Second Look home improvement www.SecondLookHome.com Handyman and Home Repair Specialist in Rhode Island RI Licensed Lead Safe Remodeler/Renovator, RI Registered & Insured Contractor |
Re: Lally Column Footer Depth
Read posts below ...
Recovering IT Guy
Thanks for the quick reply! I hadn't thought about portland or rebar... great suggestions.
Trade: Residential General
Good safe size????
umm I would by no means say that a 2'x2' is a "good safe size" Throw in some portland?? What? Do you know how to calculate the load on those columns? Can you tell us what type of soil is under the basement slab? |
Commercial construction
Trade: Commercial construction
Second Look,
Check with an engineer, or the local code enforcement office. Best Regards, Michael Last edited by mikesewell; 03-30-2007 at 04:36 PM. |
Oops:
I went back and re-read the poster's information... Thus, I will say this; Thanks for the heads up Mike. Proper answer: Footing sizes and especially depths are calculated by soil types/classes and the structural loads they will carry. Thus, the footing sizes are generally established by a registered design professional.....
- Build Well - Last edited by AtlanticWBConst; 03-30-2007 at 04:38 PM. |
#7 | |
Re: Lally Column Footer DepthQuote:
- Build Well - |
Our home is 13 yrs old The support beams are 3-2x12's nailed together supported by steel columns which are resting on the concrete basement floor.
I do not know if there are pads underneath, but there has been no cracking to date. There where many questionable construction methods used here that have resulted in problems, but this does not seem to be one of them. |
Me either.
Best wishes. |
Recovering IT Guy
City building dept returned my call today so my question is answered with a view towards local soil conditions. Thanks to everyone who contributed.
Trade: Tile/Stone/Remodeling
The pads that we have placed ranged from 24" square x12" deep or 36" square x 12". In one high end town we had to make our pads 48" square x 12" deep with #4 rebar in a grid pattern. Most pads didn't require rebar but it never hurts.
#13 | |
As you have mentioned, every case is different. The connection details are VERY important. You don't want the beam coming off the column during a partial building collapse or during an earthquake. Always hire an engineer for your heavy structural work; lives are at stake. |
| What are column inches? | georgia dawg | Marketing & Sales | 4 | 06-04-2007 09:30 PM |
| Installing lally columns | osborneconst | Construction | 10 | 12-13-2006 08:57 PM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
| dug footer for deck, monster rock in one. | ramblemn | Construction | 7 | 06-06-2006 12:18 AM |
| Hollow steel lally or concrete filled? | kusa24 | Construction | 4 | 04-23-2006 08:49 AM |
