Kitchen Sink Window Height?
Old 06-22-2006, 09:57 PM   #1
thepawnshop's Avatar
What is the standard height to the bottom of the window behind kitchen sinks?
I have heard everything from 40" to 48" and I want to put the largest possible window behind the kitchen sink.
Thanks!
Doug Brandt
Class "A" Contractor
Brandt Custom Homes
Roanoke, VA
thepawnshop is offline
Old 06-22-2006, 10:13 PM   #2
Tom R's Avatar
Re: Kitchen Sink Window Height?
I don't know of any actual 'standard' for one, - - but what is somewhat 'standard' is your countertop would be at 36", - - your backsplash would be 4 more inches and you would need to leave several more inches for casings or apron, - - so I would say make it at least 44 inches off the finished floor height, - - that should also leave you a little allowance so your trim isn't 'squeezing' your backsplash . . .
Tom R is online now
Old 06-23-2006, 06:59 AM   #3
joasis's Avatar
We use 3/0 - 3/0s behind the sinks in our spec homes. If you went any larger, (longer) you would be getting low to the countertop.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 06-23-2006, 10:06 PM   #4
Tom R's Avatar
Sounds good, - - I would think that's putting you around the 46" range.
Tom R is online now
Old 06-30-2006, 09:47 PM   #5
Just 'Finishing' Up...
erik edlund's Avatar
Hey kids,
Basics... put the top of the window at "80 inches", measure down from that point, then follow Tom R's good advice.
Kind regards,
Erik D. Edlund
erik edlund is offline
Old 06-30-2006, 10:04 PM   #6
Teetorbilt's Avatar
Make it to fit you and a standard window size. We're still working with dimensions that were established back when the average man was 5'10". It's about time that we all grew up.
Our kitchen has two different counter heights. One for 6'2" me and another for 5'4" wife. I cook more extensivly, so I get more space.
Albert Einstein
Teetorbilt is offline
Old 07-01-2006, 06:27 AM   #7
Dan
ApgarNJ's Avatar
Send a message via AIM to ApgarNJ
no standard height for this stuff, we just did a job where the concrete countertops acted as the window sill. the architect wanted them that low
ApgarNJ is offline
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Cast Iron Kitchen Sink KentWhitten Painting & Finish Work 7 06-28-2007 09:25 PM
Condensation Help Patrick Windows, Siding and Doors 10 03-16-2007 09:40 AM
Pre Cast Window Don H Drywall 7 09-20-2006 11:01 PM
Window Seat and Bookshelves in Fonr of Baseboard Heating Richie-C Finish Carpentry 10 04-04-2006 09:05 PM
