Kind Of Like A Deck... But Its A Garage Conversion
Old 08-17-2017, 09:29 PM   #1
behancs's Avatar
Rewards Points: 30
So I bought myself a "fixer upper" and part of my plans is to finish the garage into more living space. I have a ton of ceiling space and want to bring the floor level with the rest of the house.
Simple until now... The previous owner never really maintained the house all too well and the garage slab is trashed.... (water constantly came in the one corner from a broken garage door) good news is.. I can take advantage of some of the ceiling height by "building a deck" for a subfloor... The garage is roughly 14' wide... (i will measure exact tomorrow) I figure a ledger board on each side and run the joists across wall to wall. It is an all cinderblock foundation and walls. the walls seem in fine shape. Underneath I can put my vapor barrier and insulation.
From there I do a standard subfloor then hardwood.... finishes.. blah blah blah...
Great idea or am i crazy?
Plan B would be to pour a slab over the slab and lay joists right on it... The garage door issue obviously won't exist... I will be doing a footer and block to bring it above grade....
behancs is offline
Old 08-17-2017, 10:05 PM   #2
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 10,980
Re: Kind Of Like A Deck... But Its A Garage Conversion
I was considering the same before we found the house we bought. One of the houses I lived in when I was in high school had a finished garage. Kind of a common thing to do around Memphis, Tn.
How is the current master bedroom? I think either a master suite or entertainment areas work well.
The house we had when I was a kid had the garage turned into a bedroom, family room and small tool storage area. That is where I would sneak back into the house at...lol
A&E Exteriors is online now
Old 08-18-2017, 12:04 AM   #3
VinylHanger's Avatar
Rewards Points: 7,400
We had a house when I was a kid with a two car garage converted to a big family room with a bar. I loved that house.
However, when we went to look at it, there were pictures of the entire family in diapers.
VinylHanger is offline
Old 08-18-2017, 12:13 AM   #4
Frank Castle's Avatar
Rewards Points: 1,044
I hate when people convert the garage into living space, then leave the driveway running right up and touching the house.
At least cut it back to a parking space size away from the house.
Adapt, Improvise, Overcome.
Frank Castle is online now
Old 08-18-2017, 08:43 AM   #5
hdavis's Avatar
Rewards Points: 8,067
Plenty of people just build right on the slab.
hdavis is online now
Old 09-10-2017, 06:36 PM   #6
Flip King
Gking707's Avatar
Trade: Remodel Contractor
Rewards Points: 38
Sounds like you need to solve the moisture/water issue before you do anything with either of your two plans. I dont see how moisture barrier will help with an inch of water under your subfloor. Sounds like you might end up with a moldy, dry-rotty mess.
Gking707 is offline
Old 09-10-2017, 09:42 PM   #7
FrankSmith's Avatar
Rewards Points: 4,490
I haven't seen a garage turned into a living space that didn't look like a garage turned into a living space. I personally dont like it. Add on to the back of the house or go up. Houses need garages. People have a lot of crap these days.
FrankSmith is online now
Old 09-10-2017, 10:31 PM   #8
GC/carpenter
Californiadecks's Avatar
Rewards Points: 7,042
We can't turn a garage into a living space without adding another garage.
Mike.
_______________
Californiadecks is online now
Old 09-10-2017, 11:15 PM   #9
Designer/Contractor
Rio's Avatar
Rewards Points: 1,522
Mike.
_______________
We can down here in Dago (not a slur, a nickname for a city, look up Dago Choppers) as long as two off street parking spaces are provided, that's not the driveway unless it's a double wide 25' back from the sidewalk, can't be in the front yard, whole bunch of requirements.....
To the OP's question, people do it all the time, can be okay, can suck, as Cali points out maybe a garage somewhere else. If you do do it follow the code, provide proper ventilation, access, insulation, etc..
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Californiadecks (09-10-2017)
Old 09-11-2017, 09:07 AM   #10
Fishindude's Avatar
Trade: Industrial
Rewards Points: 348
Agreed.
Pretty easy to spot the typical brick ranch home where they filled in the old garage door opening with vinyl siding .... yuk. A proper addition does not look like an addition.
Fishindude is offline
The Following User Says Thank You to Fishindude For This Useful Post:
Frank Castle (09-11-2017)
Old 09-13-2017, 07:47 PM   #11
TimNJ's Avatar
Rewards Points: 2,600
I think when he eliminates the garage door he will eliminate the water leak.
I have seen illegal conversions around here. The garage door is there from the street but there is now a room in the house.
Tacky...really tacky.
TimNJ is online now
Old 10-01-2017, 07:52 AM   #12
limeykat's Avatar
Trade: general
Rewards Points: 6
sounds good to me, the footing and blockwork across the garage door opening should eliminate the water - just don't forget some form of airflow, lack of airflow is a MAJOR factor for rot and mold.
limeykat is offline
Tiled deck pschieuer Construction 16 10-21-2015 03:16 PM
Ballpark cost for garage addition? Moze Construction 7 01-10-2015 02:21 PM
Summer deck projects C2projects Decks & Fencing 149 01-15-2013 11:24 PM
Deck 1983 Bunited2 Decks & Fencing 5 11-27-2012 01:40 PM
Deck Railing FinishingEdge Decks & Fencing 27 11-04-2012 04:09 PM
