Job Sequence - New House
Old 12-04-2007, 01:40 PM   #1
MHMConstruction's Avatar
I'm sure I'll get blasted with all kinds of "you are an idiot who should not be in this business....." but oh well........
I'm a framer/carpenter/remodeler - been involved with hundreds of houses but never built one for myself and I'm acting as the contractor on my own house.
need help with Job Sequence - is there a good resource for that? website? another thread?
for example: I don't want to have my concrete guy pouring the slab when I realize that I should have had my plumbing stubbed out first. oops. wish I would have had a more detailed Job Sequence
MHMConstruction is offline
Old 12-04-2007, 02:09 PM   #2
Hawaii Handyman Remoleing
Aaron111's Avatar
Trade: Honolulu, Hi Handyman Remodeler 510-868-8807
Send a message via MSN to Aaron111 Send a message via Yahoo to Aaron111
Re: Job Sequence - New House
Cant help you here but Im sure you will figure this one out being that you have the knowledge
Aaron111 is offline
Old 12-04-2007, 03:24 PM   #3
I used to think so.......
wallmaxx's Avatar
great book......
wallmaxx is offline
Old 12-04-2007, 03:36 PM   #4
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
House/with attached Garage Renovation
General Conditions
Finalize plans and develop estimate with owner, architect
Sign contract and notice to proceed
Apply for Permits
Secure foundation permit
Secure framing permit
Secure electrical permit
Secure plumbing permit
Secure HVAC permit
Secure miscellaneous permits
Site Work
Clear and grub lot
Excavator estimated houly
Skid steer estimated hourly
Trucking estimated hourly
Topsoil stripping
Pavement and sidewalk removal
Rough grading
Relocation of existing natural drainage
Removal of unsuitable soil
Access roads
Detours
Protection of existing structures and utilities
Environmental considerations
Install temporary power service
Install underground utilities
Foundation
Locate building
Survey
Install batter boards
Excavate for foundations
Drilling for garage piles
Forming
Footings
Total lineal feet of footing
Total width of footing
Total thickness of footings
Total cubic meters of footings
Foundations walls
Total lineal feet of walls
Total width of walls
Total height of walls
Total cubic meters of walls
Grade beams
Total lineal feet of beam
Total width of beam
Total height of beam
Total number of 12"x12' concrete pile
Total cubic meters of beams and piles
Cure basement walls for 7 days
Strip basement wall forms
Waterproof/insulate basement walls
Perform foundation inspection
Backfill foundation
Framing house and attached garge
Install 1st floor joists
Mud sill achor bolts
Sill gasket
2x6 Treated mud sill
2x10 Spruce 4 ply beam
3" Adjustable steel telepost
2x10 Spruce joisting
2x10 Spruce rim joists
2x2 bridging
Single joist hangers/nails
Double joist hangers/nails
3 1/4" coated nails
Lay 1st floor decking
3/4" T&G Fir sheating
1 1/2" flooring screws
Sub-floor adhesive
Frame 1st floor walls
Exterior walls
Top, bottom and cap plates 2x6 spruce
2x6 spruce studs 92 5/8"
3/8" spruce sheathing
2x10 spruce 2 ply header with 2x6 backer
2x6 garge door rough frame and Brick moulding
3 1/4" coated nails
1 1/2" sheathing staple
House wrap (Tyvek) and tape
3/8" house wrap staples
Interior walls
Top, bottom and cap plates 2x4 spruce
2x4 spruce studs 92 5/8"
2x4 spruce single plate door header
Plumbing wall
3 1/4" coated nails
Cap plate and exterior wall backing poly flashing
2x6 drywall backing
Install 2nd floor joists
2x2 bridging
3 1/4" coated nails
Lay 2nd floor decking
Sub-floor adhesive
Frame 2nd floor walls
Exterior walls
3 1/4" coated nails
Interior walls
Plumbing wall
3 1/4" coated nails
2x6 drywall backing
Interior stairs and landings
Complete roof framing
Manufactured Roof trusses and gables 24" o.c.
2x6 gable ladders and fascia
2x6 fasica
Cardboard insulation baffels
2x4 truss bracing and strapping
2x4 ridge blocking
1/2 roof sheathing
1/2 sheathing clips
3 1/4" coated nails
2" sheathing staples
3/8" insulation baffle staples
Conduct framing inspection
Dry In
Shingles
210 Asphalt shingles
Ice and water shield
Asphalt ridged cap
1 1/4" shingle nails
Aluminum gable flashing
Roof vents
1st floor exterior doors
Front door 36/80 6 panel with side lite
Weiser brush nickel passage and deadbolt
Back door 36/80 6 Panel
Garage man door to house 36/80 6 panel with closer
Garage doors 9x7 Barcol inusulated with Genie opener
1st floor windows
2nd floor windows
Exterior Finishes
Eaves
Aluminum vented soffit (white)
Aluminum fascia
5" Gutter and down spouts
Stucco
Scaffolding
1 1/2" styrofoam insulation
Stucco base coat
Stucco finish coat
Parging
Stone work
Shingle gables
Exterior Decks and Stairs
Utility Rough-Ins and Complete Concrete
Rough-in plumbing
Conduct rough-in plumbing inspection
Place concrete for basement floor
Rough-in electrical
Conduct rough-in electrical inspection
Rough-in HVAC
Conduct rough-in HVAC inspection
Rough-in communication - phone, cable, computer, alarm
Interior Finishes
Insulation
Wall insulation - 1st floor
R20 fiberglass batt 6ml vapor barrier
Wall insulation - 2nd floor
Ceiling insulation - 2nd floor
R40 Blown in cellulose 6ml vapor barrier
Conduct insulation inspection
3/8" vapor barrier Staples
Tuck tape
Acostical chalking
Drywall
Install drywall - 1st floor walls
Install drywall - 1st floor overhead
Install drywall 2nd floor walls
Install drywall 2nd floor overhead
Tape and float 1st floor drywall
Tape and float 2nd floor drywall
Paint
Texture all except entry and kitchen - 1st floor
Paint all except entry and kitchen - 1st floor
Hang wallpaper entry and kitchen - 1st floor
Texture all - 2nd floor
Paint all - 2nd floor
Paint exterior siding & trim work
Cabinets
Install 1st floor - kitchen cabinets
Install 1st floor - master bath and guest cabinets
Install 2nd floor - hall bath and private bath cabinets
Install chair rails, crown moldings, trim
Finish Plumbing
Complete 1st floor - kitchen plumbing
Complete 1st floor - master bath and guest plumbing
Complete 2nd floor - hall bath and private bath plumbing
Conduct finish plumbing inspection
Finish Electrical
Complete 1st floor circuits to service panel
Complete 2nd floor circuits to service panel
Conduct finish electrical inspection
Complete communications wiring - phone, cable, computer, alarm
Finish HVAC
Complete 1st floor - zone 1 HVAC
Complete 2nd floor - zone 2 HVAC
Conduct HVAC inspection
Carpet, Tile and Appliances
Tile entry, kitchen and baths
Carpet 1st floor
Carpet 2nd floor
Install appliances
Landscaping and Grounds Work
Pour concrete driveway and sidewalks
Install backyard fence
Sod and complete plantings - front yard
Sod and complete plantings - backyard
Final Acceptance
Complete final inspection for certificate of occupancy
Cleanup for occupancy
Perform final walk-through inspection
Complete punch list items
And about 200 items are missing...and if you took all this information and applied it to an excel program with numbers and functions you would have a good start to a real estimating program....or just add numbers and you would have a estimate. But now it is up to you to add the missing items.....
woodmagman is offline
Old 12-04-2007, 03:46 PM   #5
woodmagman - you are the man!!! I'll bet your fingers are tired as heck
many thanks - dats the kind of stuff I was looking for
Old 12-04-2007, 03:52 PM   #6
woodmagman's Avatar
Please send $14.95 to your local "food bank"
Old 12-04-2007, 04:25 PM   #7
consider it done, my man
tis the season for doin some givin!
Old 12-04-2007, 06:53 PM   #8
Originally Posted by woodmagman View Post
House/with attached Garage Renovation ..............................................
Rough-in plumbing
Rough-in electrical
Rough-in HVAC
Rough-in communication - phone, cable, computer, alarm.............................
I always like to do electrical after HVAC.
Least flexible first to most flexible last.
And fewer possible collisions of romex with sharp metal
neolitic is offline
Old 12-04-2007, 07:01 PM   #9
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
Good point, more guys need to learn that one. It would lower my Tums and sawzall blade budget for the year.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 12-04-2007, 07:05 PM   #10
Pain is my teacher
neolitic is offline
Old 12-04-2007, 07:21 PM   #11
GregS's Avatar
Trade: Low Voltage
I like to get in before the HVAC to run vac pipe. That way when the HVAC guy comes in to run his duct work and he cuts out my vac pipe, I can backcharge the builder for fixing it
GregS is online now
Old 12-05-2007, 07:38 AM   #12
joasis's Avatar
One thing you might wish to consider is the "wish list", in addition to the very valuable list above. Nothing worse then standing in a finished room and saying "I wish........."
The single largest screwup, besides not having media cable in, is actual room sizing and placement. "Well......it looked perfect in the prints" is a common thing. I actually had the HO's stand in a garage while I laid out 2x4's to represent walls for the bathrooms and doors, and yes, there were changes. This all happened before we broke ground.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 12-05-2007, 07:40 AM   #13
joasis's Avatar
http://books.google.com/books?id=9wk...jsBT-BAZ0jSpgA
This book will help as well.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
Old 12-05-2007, 08:45 AM   #14
dirt diggler's Avatar
Trade: contractor
General Conditions
Apply for Permits
Secure HVAC permit
Site Work
Clear and grub lot
Topsoil stripping
Rough grading
Access roads
Detours
Foundation
Locate building
Survey
Forming
Footings
Foundations walls
Grade beams
Total width of beam
Backfill foundation
Sill gasket
2x2 bridging
3 1/4" coated nails
Sub-floor adhesive
Exterior walls
3 1/4" coated nails
Interior walls
Plumbing wall
3 1/4" coated nails
2x6 drywall backing
2x2 bridging
3 1/4" coated nails
Sub-floor adhesive
Exterior walls
3 1/4" coated nails
Interior walls
Plumbing wall
3 1/4" coated nails
2x6 drywall backing
2x6 fasica
2x4 ridge blocking
1/2 roof sheathing
1/2 sheathing clips
3 1/4" coated nails
Dry In
Shingles
Asphalt ridged cap
Roof vents
1st floor windows
2nd floor windows
Exterior Finishes
Eaves
Aluminum fascia
Stucco
Scaffolding
Stucco base coat
Stucco finish coat
Parging
Stone work
Shingle gables
Rough-in plumbing
Rough-in electrical
Rough-in HVAC
Interior Finishes
Insulation
Tuck tape
Acostical chalking
Drywall
Paint
Cabinets
Finish Plumbing
Finish Electrical
Finish HVAC
Carpet 1st floor
Carpet 2nd floor
Install appliances
Final Acceptance
wow
wood - ya oughta be chargin for that list
Thanks in advance!!!
dirt diggler is offline
Old 12-05-2007, 09:45 AM   #15
woodmagman's Avatar
Diggler, It is not mine to charge for, it is a process that is as different as the house that is being built. You know how the guy has a shop full of tools and all he builds are ashtrys, this is what will happen with this list. Those that really know what to do with it already have one, and those that don't just feel good because they now have one in the saved documents file... Now send your $14.95 to the food bank, some people out there, tradesman included may need your help this year. If $14.95 is to easy to give then give till it hurts a little......Seasons Greetings...
Old 12-05-2007, 12:00 PM   #16
DeanV's Avatar
Trade: Painter
Paint
Cabinets
Paint walls before trim is installed, unh-unh. Prime drywall, then install all trim, and preferably all cabinets, counter tops, tile floor, etc. Then painters can mask off everything and leave it all with a nice, sprayed finish. Shoot, sometimes I think I would like to comeback and do the final coat on all the walls after the carpet is installed even (can you tell I am sick of giving away my time fixing scuffs and dings from the trades after the painters)
DeanV is offline
Old 12-08-2007, 05:47 PM   #17
President
Marquis's Avatar
go to Marquis Home Builders, Inc website marquishomebuilderscom and click on the Construction Process. It has 65 phases and they are pretty much in order of how you would normally construct a residence. It is not crazy detail but may help.
Marquis Home Builders, Inc.
Marquis is offline
Old 12-09-2007, 11:38 AM   #18
skylands's Avatar
Trade: restoration
OK. I'll start
A few years back I had a contract for a shell addition. HO was doing all the finishwork.
We hung all the rock on Friday. The spackler showed up on Monday to be turned away because the HO and his brother installed the hardwood floor over the weekend and were staining it.
skylands is offline
Old 12-09-2007, 12:09 PM   #19
Mod / ArchiBuilder
Cole's Avatar
Originally Posted by skylands View Post
OK. I'll start
You have to be kidding me!
Cole is online now
Old 12-09-2007, 01:14 PM   #20
Scott dev's Avatar
Trade: Cabinet builder/installer
Some great stuff guys, very interesting. Where I am in Alberta Canada the electrician won't rough in until plumbing and heating are roughed in. As for painting we only prime and then maybe one coat of finished color, then we do all are finish carpentry, cabinets, tile, etc, then painter finishes.
Have fun, I built a few houses for myself over the years and have always enjoyed it.
Scott dev is offline
Did you see Flip this house - Cat House? SuperiorBuilt Off Topic (Non Trade) 18 01-24-2011 05:17 PM
Raining in the House oldfrt General Discussion 9 11-07-2007 11:10 PM
House moving Toolwh@#e Excavation & Site Work 10 10-21-2007 11:23 PM
what 2 use 4 water line to house? national Plumbing 15 10-04-2007 11:31 PM
`Flip This House' star accused of fraud AmeliaP General Discussion 28 06-03-2007 10:21 PM
