Jack Stud Sizing Under Window Headers?
Old 01-08-2009, 08:27 AM   #1
stranchina's Avatar
Does anyone know the actual ruling of IRCC2006 for the minimum size that a "jack stud or trimmer" can be under a exterior wall window header. I have used a double 2 X 12 with 1/2" OSB for a exterior wall window header on a 8' high window and my framer wants to use less than a single 2X for the window trimmer. I have never seen anything less than a 2X single or a double 2X used for support.
Can anyone help me find a ruling of minimum sizing for trimmers under this circumstance.
Thanks
stranchina is offline
Old 01-08-2009, 08:45 AM   #2
Pompass Ass
bwalley's Avatar
Re: Jack Stud Sizing Under Window Headers?
Thanks
You are the General Contractor, tell the framer how You want it done, you are the one running the job, not him.
I deal with FBC, so I don't know what the IRCC would be, but all building codes are the "Minimum" requirements.
bwalley is offline
Old 01-08-2009, 09:25 AM   #3
Carpenter
tcholdren's Avatar
height dosnt matter on eight foot wall! length of header determins how many trimmers to install. four feet and under one trimmer each side, over four feet double trimmer each side.
THConstruction
tcholdren is offline
Old 01-08-2009, 09:44 AM   #4
Dave R's Avatar
Trade: Home renovation and repair
It depends on what the header is supporting. Just a roof and ceiling; Roof and ceiling and one center bearing floor; roof and ceiling and 2 clear span floors etc.
Assuming that you used the 2 (2x12) header based on code requirements, I don't see anywhere that you can get by with less than 2 jacks under each side of the header. At least this is required in North Carolina which is based in the IRC.
Dave R is offline
Old 01-08-2009, 10:26 AM   #5
Joe Carola's Avatar
Trade: Framing Contractor
Thanks
What does he want to use, a piece of 5/4 or 3/4? Why does he want to use something smaller than a 2x, did he cut the headers short?
Joe Carola
Joe Carola is offline
Old 01-08-2009, 11:05 AM   #6
Tom Struble's Avatar
Trade: siding
thats what i was wondering
Tom Struble is offline
Old 01-08-2009, 05:30 PM   #7
precisionbuild's Avatar
Trade: Contractor
The jacks have to be nominal 2x by code.
Table 502.5 give the number of jacks for spans, # of floors, building width, etc.
precisionbuild is offline
Old 01-08-2009, 05:31 PM   #8
Trade: Contractor
This...
Old 01-08-2009, 06:23 PM   #9
Make it Happen!
Rick954's Avatar
Trade: Project Super
i also agree with that.
recognizing stupidity is a large part of running a job in my opinion. dont let it sneak up and trick you into something dumb.
Rick954 is offline
Old 01-08-2009, 09:26 PM   #10
canadianwood's Avatar
Code in Canada according to NBC is that it must be minimum 1 1/2" bearing for lintel spans of less than 10' and 3" for over 10'. But I wouldn't go more than 6' with single jacks. Do NOT go less than 2x material for any span, inspector will not pass this as long as he's awake.
BTW, it sounds like the framer might have f***ed up the RO size, then tried to hack in 1x material.
canadianwood is offline
Old 01-08-2009, 09:52 PM   #11
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extrordinaire
That sounds right.
I have never had a problem from inspectors going up 6' with a single 2x and two 2xs wider than that.
Andy.
ScipioAfricanus is offline
Old 01-08-2009, 09:53 PM   #12
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
I've never seen anything less than a 2 x either for a jack stud bearing wall. Can't quote that in the code book but I doubt it's legal.
KennMacMoragh is offline
Old 01-08-2009, 09:59 PM   #13
Joe Carola's Avatar
If the framer did screw up with short headers, depending on how many, without ripping them out he can try to use the Simpson HH hangers. If not, he has to fix it.
http://www.strongtie.com/products/connectors/hh.asp
Joe Carola
Old 01-09-2009, 01:10 AM   #14
OGStilts's Avatar
Man, I thought for sure you guys would eat him alive. This guy can't be real. Guess I will look for my entertainment somewhere else tonight.
OGStilts is offline
Old 01-13-2009, 09:58 PM   #15
D.Foster's Avatar
Trade: Carpentry & Remodeling
Its usually on my prints, how many jacks. It is good to know the gen rules tho. But show him the plans, if it is in print, and if it fails he will have to fix it.
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 01-13-2009, 11:33 PM   #16
Code Nerd
Deadhead Derek's Avatar
Trade: Historic Preservationist / Furniture Maker
yup. nothing less than a single per side 4' <
plans should spec. requirement i.e. load path, point load etc above.
www.darkstarltd.net
Hand-crafted Traditional Masonic Furniture
and Coffins
Deadhead Derek is offline
Old 04-18-2011, 12:08 AM   #17
CONTROLGUY's Avatar
Trade: Engineer---Electrical and Controls Company
CONTROLGUY is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Jack stud question billderboots Framing 45 12-31-2008 07:13 PM
Reno Window Screw Up Bummie Windows, Siding and Doors 15 12-22-2008 10:33 PM
Basement Window Leaking DanTheMan9727 Construction 3 10-24-2008 02:29 PM
