Trade: Log home builder
Isulating With Foam For Roofs?
I've always used fiberglass for insulating roofs but I'd like to try EPS foam. I have a RT59 Grove crane so I'll be able to lift any size panels. What are the better companies and products? I've heard there is some real bad kinds of foam. Thanks
Bah Humbug!
Re: Isulating With Foam For Roofs?
Insulating attics or insulating roofs? Typically the only ROOFS that get insulated are vaulted ceilings, where the roof deck is exposed and usually a T&G type board, or the obvious flat roof. Insulating a roof is most effectively done with PolyIsoncyanurite, or ISO for short.
i dont know bout foam insulation describe
| Foam Board vs. OSB | JimmyZimmier | Framing | 17 | 11-06-2010 05:54 PM |
| spray foam? | jcovey | Construction | 8 | 02-27-2010 09:19 PM |
| Spray foam insulation? | tgeb | Insulation | 5 | 12-16-2007 11:11 PM |
| Sill Seal, i've always used the foam | eXpatRioteX | Framing | 2 | 05-24-2007 06:28 PM |
| fastening wire + wrap to foam insulation | mas | Construction | 0 | 07-07-2006 10:39 PM |
