Casey
Trade: framer
Insulation Vapor Barrier? Yes Or No?
Do any of you use a vapor barrier when you insulate a new home or addition. Some guys use it and others will not.
In talking to a Owens Corning Rep, he said a plastic vapor barrier should only be used with unfaced insulation. I have heard pros and cons both ways. Any opinions? |
Trade: Framing
Re: Insulation Vapor Barrier? Yes Or No?
Vapor barrier is dependent upon where you live.
Go to the building science web site for the explanation. |
Rory Read
Trade: Residential Building and Remodeling
Everything I read these days tells me I do not want to trap moisture inside a wall assembly. It's got to breathe one side or both.
I think the best article to start with is the Building Science Corporation research report titled Vapor Barriers and Wall Design. It's worth wading through, and it details different options for different climates/regions in the US. You can grab it off their site. Cheers, r |
Rory Read
Sorry Framer53. Just behind you there. Didn't mean to echo.
R |
Trade: carpenter
You need a VB if you are using fiberglass insulation. If you are using spray foam - no. If you use rigid foam panels under 2" - yes. Two inch foam does not require VB.
If you are using paper back insulation, with a tar like substance on the back of the paper, then this is the VB, and do not put another VB over this. Normally builders use fiberglass with 6mill poly over it. All seams should be overlapped and caulked with accoustic sealant. There are a few other considerations, and special situations, but never apply two VB |
Trade: carpenter
Just read the above posts, and yes, it depends on your climate.
Sorry, I assumed you were in a cold climate. I have no idea if it is required in a hot climate like Florida or California. |
| The Following User Says Thank You to katoman For This Useful Post: | Framer53 (02-08-2010) |
#7 | |
Trade: Framing
Re: Insulation Vapor Barrier? Yes Or No?Quote:
"Pro"
Vapor Barrier goes to the warm side. (In warmer climates that would be facing the outside)
Dan |
I just saw a program on cable saying it is unhealthy to seal the house airtight. People are getting an increase in respitory illnesses in the colder climates as a result of this. LOL
#10 | |
Trade: carpenter
Our building code will make changes now and over the next 3 years to make every new home built to these standards. It is like living in a plastic bag, then they install air exchangers to get some air into the home, and most of them are sized wrong, or installed incorrectly. What a mess. I prefer that a home should be able to breath. But apparently I'm in the minority. The public is basically ignorant in these matters, and only wants a lower monthly heating bill. There's no changing it now. Wait 20 yrs. and I'll bet they start going back to the old way. |
#11 | ||
Sean
If someone can't size it properly, you need to find a new company as the math is really simple Oh & I wouldn't connect them to the HVAC system either - a tighter house doesn't require as much heating and cooling and you have no way of knowing how the HO will actually use the system, it is better left as a standalone system |
| The Following User Says Thank You to SLSTech For This Useful Post: | rustyjames (02-09-2010) |
#12 | |
Trade: design / build defense contractor
#13 | |
Trade: carpenter
Now, you recomend that the HRV be kept as a seperate system? Then seperated ductwork is run to bathrooms, kitchens, etc.? The sysems they did were connected to the heating system. Makes sense, I probably need to look into this a little further. Thanks. |
If they are not using a vapor barrier, then they are probably planning on using PVA, which is also my own preference. But yes, some form of vapor barrier has to be used.
Trade: small job residential framing (backyard buildings)
In a cold climate vapor barrier prevents water vapor from entering the stud bay and condensing onto or into the insulation. Not necessary in warm climates, check local codes and reputable builders in your area to see what they recommend. In my house, a vapor barrier would be a waste of time since I leave the window vents open year round and in the warmer weather, crack at least two or three windows for fresh air. BTW, I have heard that some builders use a spray on VB with the primer, not sure if that is effective or not.
Re: Insulation Vapor Barrier? Yes Or No? |
#17 | |
Fortune and glory, kid.
Trade: Carpentry & Restoration/Remodeling
If your house could stay comfortable in a cold climate throughout the year without even a primary heat system, why wouldn't a person want that? Gas bills for old brick or stick here in St. Louis can run $200-$600/month in winter. Superinsulated (with proper functioning heat exchange/ventilation) is the future of building, no question in my mind, and it should be. http://www.passivehouse.us/passiveHouse/PHIUSHome.html |
#18 | |
I have been doing Injection Foam Insulation for the past year and a half with great results. It's a BIG learning curve but really does a nice job in filling an enclosed cavity with foam insulation. The product I use has a pretty good R-4.6/inch, so I can get an R-16+ in a 2x4 wall. NO its not Retro Foam, I looked into that and its problems. I have done my homework, any questions just ask......Bryan
| The Following User Says Thank You to PREMIER INSUL For This Useful Post: | moorewarner (03-16-2010) |
| Should you pay more for a quality insulation job? | ecworks | Insulation | 0 | 01-20-2010 06:05 PM |
| Insulation Blower? | MEL | Insulation | 7 | 11-25-2009 12:07 AM |
| Foam Insulation - Close and Open Cell | AMS Co | Insulation | 4 | 10-09-2009 05:08 PM |
| Need some expert advice for attic insulation | bean | Insulation | 1 | 03-12-2009 03:42 PM |
| Radiant Barrier Fact Sheet | Ed the Roofer | Roofing | 0 | 02-09-2008 08:57 PM |
