Gen. Contractor
Trade: Residential small commercial
Insulation / Stucco Question
What is the R value of 1"foam and stucco?
"slow makes smooth, smooth makes fast" |
Sean
Re: Insulation / Stucco Question
Stucco basically equals a 0 - what type of foam?
If it is that standard cheep white crap - right around 3 (possibly up to a 4) if they didn't smooth it down a ton and it is the newer formulas. That said I have seen some that come in around a 2 & some of the newer product offerings at a 5 |
Gen. Contractor
Thanks- I'm starting a house and the HO wants the walls to have an R value of 28, it looks like I'll have to spray in foam and blow in a blanket to get it.
Trade: Metal Roofs, REMOs, and EX Beer Drinking PRO
The standard foam for EiFs is 4.5 per inch, and has better perf value then fiberglass or cellulose
The thing people need to relize is a well sealed Eifs will act just like a styrofoam cooler or cup (think of hot coffee in the cup not burning your hand) you also break the thermal bridge and so on |
Sean
Not necessarily - one option is 2x6 with dense packed cellulose which gets you close to R20 in the cavities, add sheathing, drainage wrap or Tyvek, then 2 - 1" layers of R5 stucco foam offset (or Red's R4.5) & you are now at R30 (29) - as for the whole assemblies RValue, that would be less due to framing & windows but that is another thread
| The Following User Says Thank You to SLSTech For This Useful Post: | Tom Struble (05-03-2012) |
Thom
I don't quite understand the fixation with high values for wall insulation.
It seems 90% of your heat gain/loss is through the ceiling/roof, of the remaining 10%, 90% of that is through windows and doors. Several years back I was talking to a guy building his own house out of concrete/styrofoam walls. He was bragging about the great R-value while the entire east facing wall (the longest wall in the house) was two story glass.
"Government is a disease masquerading as its own cure." Bob LeFevre. |
| The Following 3 Users Say Thank You to thom For This Useful Post: |
Trade: siding
right Thom and the issue is not so much total wall insulation as it is how much is in the wall cavity and how much is outside it
Tom |
#8 | |
Sean
Re: Insulation / Stucco QuestionQuote:
The reason most see the attic / roof area as the biggest culprit is a combination of bad building practices (especially up north) coupled with a higher Delta T (warm to hot climates) - One reason why I am a fan of hot roof assemblies is the dramatic difference in Delta T which in some cases means less insulation is really needed As for windows & doors being a big culprit - generally this is not the case, the issue generally revolves around bad air sealing & people walking by & feeling a draft. In some cases with single pane windows they may actually feel a draft when there isn't one as heat moves to cold & what you are feeling is a convection current created by this principle & you. In this case, installing a good storm window will give you better results. Now as for the poor siting of a house, well... |
| The Following User Says Thank You to SLSTech For This Useful Post: | ScipioAfricanus (05-09-2012) |
Trade: GC, Remodeling
I think the roof is the biggest culprit more because Heat rises. |
Trade: siding
hmmm..interesting..
Tom |
My stucco Guy says when hes done its R-10 Achieved and he uses the white Styrofoam so i called BS right off the batt.
but there are companies here that sell R14 guaranteed with there system and i think its a layered system using rigid board, not to sure tho, can anyone shed some light on this
Custom Decks Custom aquarium all salt water Renovation next on my list............planting trees for all those material i used |
Woodologist
Trade: residential construction
Typical rigid 1" = R5. 2"=R10.
I've been doing a 1" rigid on exterior for thermal break. Then 2" spray foam in cavities for air sealing/r value. And fill the rest with blown in fiberglass. |
I'm a Mac
Trade: ICF Construction
The 2" white styrofoam EPS at 1.4 lbs per ft is R10.
Chris |
Trade: mason
Re: Insulation / Stucco Question |
I'm a Mac
It's based on density of the foam
Chris |
| Foam Insulation - Close and Open Cell | AMS Co | Insulation | 4 | 10-09-2009 04:08 PM |
| Another stucco question | CJKarl | Masonry | 1 | 10-03-2009 04:35 PM |
| question on synth stucco | stacker | Masonry | 2 | 08-29-2008 08:59 PM |
| Radiant Barrier Fact Sheet | Ed the Roofer | Roofing | 0 | 02-09-2008 07:57 PM |
| Insulation question. | Rich Turley | Remodeling | 14 | 06-11-2006 02:21 PM |
