Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction
Old 11-21-2006, 03:13 PM   #1
Trade: Grading, excavating, builder
Installing lally columns
I am a new builder and I find a lot of useful info on this site. I just got my first job, a small house, only 912 sq.ft. The plan has changed some and now involves a steel beam and 1 lally column. I need some help with the proper way to install lally column. The column will sit on a large concrete pier in the basement. Do I need to pour the pier and then install the lally column or install the lally column when I pour the pier. There will be a 4" floor poured, and I dont want the column and plate to stick up out of the floor. How do you guys do it.
Thanks for the help
Mark
osborneconst is offline   Reply With Quote
Old 11-21-2006, 03:31 PM   #2
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
When the mason pours the footers, he should pour a pad for the column. Have the beam set and the framers will set the column in place and level it up. Then you can pour the floor later.
rino1494 is offline   Reply With Quote
Old 11-21-2006, 05:53 PM   #3
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Send a message via AIM to skymaster
Here In NJ and probably most everywhere else, that column has to sit on its own footing. Per Rhino when the footings are dug for everything else have em set one for your column,have framers get the steel header set on temps, pour footings when set, put your CEMENT FILLED column in, pour floor.
JackM
skymaster is offline   Reply With Quote
Old 11-21-2006, 08:20 PM   #4
The column does have its own concrete pier. The basement will be superior walls(no concrete footing) as most of you probably know. I just didnt know if I needed to set the column as the pier and the floor were being poured or pour the pier, then set the column as the floor was poured. Thanks for your replies.
Mark
Old 11-21-2006, 10:34 PM   #5
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Mark; If I understand correctly, you already have a footing in place, then I would set that column before you pour the floor. This way it cannot be knocked out from under the header. Here that is how we have to do it, also as I mentioned cannot use jacking columns, solid filled. I fairness I have heard a few times that if jacking are used you MUST weld em once set to height, however that I cannot verify, with solid fill no questions left to answer
JackM
Old 11-22-2006, 05:45 PM   #6
Mark
So the pier is dug, but not filled with concrete yet? Pour the pier first. Superior has precast piers that they supply with their walls. I saw them use them on a house near me this summer. Personally after seeing the precast pier, I would pour my own.
TimNJ is offline   Reply With Quote
Old 11-23-2006, 08:54 AM   #7
Vagitarian
rino1494's Avatar
Mark
If it is superior walls, then they should provide you with a square pre-poured pad. The framer should dig up the stone and place the pad, then set the column under the beam and level up the beam. Then pour as normal.
Old 11-23-2006, 09:13 AM   #8
Trade: Framing Contractor
Just curious as to why the framer should dig up the stone and place the pads?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-23-2006, 10:19 AM   #9
RobertCDF's Avatar
Trade: Custom deck builder
Around here they pour the piers at the same time as the footings. They then put a small piece of 12" sonotube over the pier. Then they pour the floor. When the framers get there we set our beams on temps and mesure from pier to beam and order posts. Place the posts and concrete guys add concrete around base to match with the floor later.
RobertCDF is offline   Reply With Quote
Old 12-13-2006, 03:04 PM   #10
Trade: Siding, Windows, Decks, Roofs
The one-piece lally columns that have only 4 inches of adjustment are code in NY (and most other states i know of)-but the ones that are two tubes and adjustable are not as you say.
AllGoNoShow is offline   Reply With Quote
Old 12-13-2006, 08:57 PM   #11
Greg Di's Avatar
Trade: Remodeling & Decks
On retrofits, I cut the lallys on site to whatever they need to be. Mark the cut line, cut the steel with a grinder and then lop off the waste with a hammer blow. The concrete usually breaks really cleanly.
Don't get me wrong, it's a pain in the neck to cut a lally column, but it's not hard to do.
Greg Di is offline   Reply With Quote
installing new thru-wall flashing @ existing wall. TAO Masonry 5 08-08-2007 04:26 PM
railings and columns on bluestone kylemfk Decks & Fencing 3 04-18-2007 04:08 PM
Lally column footer depth Second Look Construction 12 03-31-2007 11:29 PM
Structural Columns new concept of columns edraeco Construction 1 03-25-2006 10:11 PM
Installing Interior Doors Richie-C Carpentry 4 03-15-2006 05:48 PM
