View Poll Results: Is the beam ok?
Yea we do it all the time 1 33.33%
Sounds about right 1 33.33%
Got no clue, I'm not an SE 0 0%
Have you lost mind 1 33.33%
Voters: 3. You may not vote on this poll
INPUT Please?
Old 05-06-2004, 09:55 PM   #1
Custom Builder
Glasshousebltr's Avatar
INPUT Please?
Any one know what the per sq inch lb rating for a concrete block wall is?
Have a block wall with a 14 foot(21lbs per) 10" steel beam with 2 stories loaded on it. I thought it was fine, I fiiled the 2 stretchers with mortar and rebar to each side.
A phisics professor from a local school said no way, even has my customer covinced, The SE said it's fine. To no avail. Customer wants steel post.
I know I've done this a hundred times and the deal is done and said, but I was wondering what you fellas thought.
Bob
Glasshousebltr is offline
Old 05-06-2004, 10:24 PM   #2
Bah Humbug!
Grumpy's Avatar
Re: INPUT Please?
I'm no engineer. Ask your local building inspector. I assume it has to be inspected anyways.
Grumpy is offline
Old 05-06-2004, 11:26 PM   #3
General Contractor
hatchet's Avatar
Re: INPUT Please?
The building inspector is obligated to go with what the construction drawings that were stamped by the SE. If you change it - you should have the SE sign off on it.
Rich
WIT Construction Co.
Superior MT Contractor
hatchet is offline
Old 05-07-2004, 01:25 AM   #4
Teetorbilt's Avatar
Re: INPUT Please?
Glass, my book is showing it as 1,000 to 3,000 P.S.I. In a habitat, I would use the lowest figure. The safety factor is not included, for humans it is usually 3 to 1. To be on the safe side, I would consider 333 P.S.I. as a maximum. Legally, you can work off of the max compression and go for 1,000 P.S.I.
I would check with the block manufacturer for their rating, it would make everything much smoother for you.
Teetorbilt is offline
input home voltage problem crunch Electrical 14 12-05-2006 09:54 PM
Need some eqp trailer input? Glasshousebltr Excavation & Site Work 13 07-18-2006 05:24 PM
Opinions and input on partnership CNC Business 17 05-24-2006 05:00 PM
mini skid steer input please cdac Landscaping 40 04-16-2006 02:01 AM
