Ideas On Removing The Roof
Old 04-18-2007, 09:08 PM   #1
ATS's Avatar
Trade: Electrical and mechanical contractor
I'm in the process of rebuilding an old concrete block barn that's about 1500 sf, 50' long. The current roof structure is shot, all 2x8 rafters sitting on a built up girder. (3 2x8's nailed together). Since the complete roof is shot, shingles, plywood most of the 2x8's, I'm replacing the whole thing with trusses. Any ideas on the best way to go about this without damaging the existing CMU walls, about 8' high. I could remove it piece by piece but I've done this before and it's dangerous and time consuming. Looking for a better way and still save my walls, thanks.
ATS is offline
Old 04-18-2007, 10:05 PM   #2
Home Repair Specialist.co
hrscammisa's Avatar
Trade: carpentry
Re: Ideas On Removing The Roof
you could put a stong back down part of it and cut it loose and lift it off in big pieces.
hrscammisa is offline
Old 04-20-2007, 07:24 AM   #3
72chevy4x4's Avatar
cut the middle one third out, leaving the one third on each end. Install the trusses in the middle and shore up-then tackle the ends. Support the 2x8 girder before cutting or else the roof may collapse when cutting the middle one third out. Might be a good idea to check the walls for plumb-being concrete I'm not sure you can do anything about them. Is there already a wood cap on the top of the concrete blocks to fasten the trusses too? Use an approved metal connector for this task.
72chevy4x4 is offline
Old 04-25-2007, 02:52 PM   #4
ATS's Avatar
Thanks for the good ideas. Plans changed now, I want to make the barn taller so I can put a truck lift in there. Now I guess I'll have to build walls on top of the concrete block and then truss it from there. I also want to fill the cells with concrete and add some rebar to beef it up some. The walls are plum for the most part so I don't think they will move once the roof structure is off but I guess some bracing would be a good idea anyway. Any opinions on raising the height another 7-8'?
ATS is offline
Old 06-09-2007, 05:46 PM   #5
MFWIC
Tmrrptr's Avatar
Trade: house painter
and now u want to go 7-8ft taller than what was dangerous before?
Ha! Ha!
They used flying buttresses on Notre Dame.
You might want to talk to an engineer.
r
Tmrrptr is offline
Old 06-09-2007, 06:25 PM   #6
mdshunk's Avatar
Um... yeah... get an engineer. I doubt that there are the CMU pilasters in place to make the walls that tall.
mdshunk is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Ideas for venting a shed roof.... kermmonk Roofing 5 08-16-2006 09:40 PM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
