I-Beam Installation
Old 11-01-2017, 11:33 PM   #1
blbranch63's Avatar
Trade: Residential Renovation
I-Beam Installation
Anybody have any suggestions of a quality/affordable jack to use to install a steel I-beam? We are installing in place of a load bearing wall in a kitchen per structural engineer specifications. Jack needs to be able to extend 8-10 ft. Any suggestions welcome. Thanks!
blbranch63 is offline
Old 11-01-2017, 11:44 PM   #2
tjbnwi's Avatar
Rewards Points: 1,790
Re: I-Beam Installation
Couple of material lifts.
https://www.homedepot.com/tool-truck...412/index.html
tjbnwi is online now
Old 11-01-2017, 11:49 PM   #3
Talking Head
EthanB's Avatar
Rewards Points: 14
yeah. How heavy is it?
Planer.....
EthanB is offline
Old 11-01-2017, 11:54 PM   #4
Dirtywhiteboy's Avatar
Rewards Points: 7,878
Yea,, we just rent the DH lift.
Dirtywhiteboy is offline
cedarboarder (11-04-2017)
Old 11-01-2017, 11:55 PM   #5
blbranch63's Avatar
About 350 lbs.
Old 11-02-2017, 12:19 AM   #6
GC/carpenter
Californiadecks's Avatar
Rewards Points: 3,674
One should do it, if it's only 350lbs.
Mike.
_______________
Californiadecks is online now
Old 11-02-2017, 07:11 AM   #7
blbranch63's Avatar
This I-Beam is replacing a load bearing wall. They have an LVL running across the house the LVL has a seam right where the existing wall is positioned. In order to remove that wall I need to support both sides of the LVL any suggestions on jacks I can use for that?
Old 11-02-2017, 07:16 AM   #8
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,195
Temporary studs. You don't need a jack for that.
Tinstaafl is offline
Old 11-02-2017, 09:38 AM   #9
gbruzze1's Avatar
Rewards Points: 2,608
350 pounds? Not sure I’d mess around with a lift. Just a few able bodied, a couple step ladders and maybe some 2x4 scraps to build a “ladder”.
But if you must...
The jack were only on those temp posts to lift the ceiling level before placing the beam. Temp walls as suggested on either side is all you need.
gbruzze1 is offline
Old 11-16-2017, 06:31 PM   #10
madmax718's Avatar
Trade: General
Rewards Points: 3,206
You can rent or buy. I keep a few around. Not expensive and have multiple lengths. I prefer the screw Jack for minor adjustments. Make sure you support the floor below. Your transferring a huge point load.
madmax718 is offline
Old 11-16-2017, 06:51 PM   #11
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,299
We rented a Genie lift today to set two 450 pounders. Getting the lift into the house and set up is more work than actually setting the beams.
Easy Gibson
Warren is offline
The Following User Says Thank You to Warren For This Useful Post:
Californiadecks (11-16-2017)
Stone veneer installation ws6tbird Masonry 7 10-01-2012 10:10 PM
Advice sought on prefinished hardwood installation UpNorth Flooring 5 07-28-2012 09:31 PM
Help quoting a steam showe installation. aulona Remodeling 3 06-15-2012 11:22 PM
Cantilevered beam in basement LetItBeLEED Framing 6 12-01-2009 10:56 PM
