How To Dig Out Basement
Old 01-27-2009, 12:32 PM   #1
AustinDB's Avatar
Rewards Points: 518
Looking at a job where the basement depth will be increased by 2' to make the basement 'useable'. New addition will be added and access will be easy, except for the low headroom of approximately 6'-6'6". No overhead lifting-but still a bobcat may not fit. I'm sure a Dingo would, but may take a considerable amount of time to remove 2'.
AustinDB is offline
Old 01-27-2009, 12:42 PM   #2
wyoming 1's Avatar
Trade: General contractor
Rewards Points: 520
Re: How To Dig Out Basement
What are your plans against the exsisting walls and footers?
wyoming 1 is offline
Old 01-27-2009, 01:11 PM   #3
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,878
When you go from 6' deep to 8' deep you are not just adding 30% to the lateral load on the wall/footing, you are adding about 80%, which can easily cause a failure or movement. As Wyoming said, you must be concerned with lateral support while digging, during construction and when it is finished.
Also, you should not dig any closer to the existing footing than the depth you are blow the existing to pour a neww footing/curb.
There is nothing worse than having a problem that causes settlement or lateral movement and cracking all through the house (VERY BIG $$$s!!!!!) the walls are holding up.
You should have someone lokk at the situation before you run off and start digging. The equipment you use is a minor problem unless you use the "bigger the better" philosophy.
Do it section by section and then wall by wall. - While you are there, interior drain tile to a sump is a "dirt cheap" investment before you pour the floor.
Dick
concretemasonry is offline
Old 01-27-2009, 04:54 PM   #4
AustinDB's Avatar
Rewards Points: 518
thanks for the concern-the existing outer block walls are coming down, new footing going in and wall to top it out. If the bottom 4 four courses of block (then sill plate) were in good condition, I would consider underpinning in thirds. But as condition of subterrain block is poor, makes the most sense to start over. I've got this part licked-still looking for feedback on the original question :-)
AustinDB is offline
Old 01-27-2009, 05:26 PM   #5
Rewards Points: 2,000
Look through the excavation
and demolition fora (forums).
There was a guy here from...
Cincinnati(?) who had equipment
made for this kind of work.
Can't remember a name, but it was
probably last winter/spring-ish?
Or you could do it the way my
Grandpa did.
Get DuPont to help!
Good luck.
neolitic is offline
Old 01-27-2009, 05:44 PM   #6
Structural Engineer
Aggie67's Avatar
Trade: Mechanical, Structural
Ever use a Dingo TX? Not an excavator, more of a loader. Low height. I think I have pictures of us digging out aluminum fines from a separation pond with that thing. We had a problem with the support steel for the skimmer arms being low and all over the place, and we couldn't drive an excavator into the thing. It worked pretty well for a bulk of the material. But all it did for us was push the solids into a small dumpster, which we lifted out with a Lull. The pond was about 50 feet in diameter, 9 feet deep, shaped like a salad bowl. We took out 140 yards in a few days. Customer made a nice buck recycling that.
But I'm not sure that would work for you. The stuff we moved out was the consistency of wet sand, and it was easy to push around.
Aggie67 is offline
Old 01-27-2009, 06:14 PM   #7
backhoe1's Avatar
Trade: excavating contractor
Rewards Points: 182
I did a job real similar this summer, bobcat 742b did every bit of it, machine is only about 6' dug down to grade and backed out. we dug out a 24x32 foot add'n roughly 4' deep in one day.
backhoe1 is offline
Old 01-27-2009, 06:24 PM   #8
Professional Instigator
rbsremodeling's Avatar
WTF? is the question. You really did not ask a question? What is it that you want to know
rbsremodeling is offline
Old 01-27-2009, 07:39 PM   #9
plazaman's Avatar
Rewards Points: 1,158
by hand, thats how we do it when the rare opportunity comes by
plazaman is online now
Old 01-27-2009, 07:52 PM   #10
Don't know if it helps,
but this is the guy I was
thinking of.
http://www.contractortalk.com/member...-buster-19433/
Maybe you'll get some ideas.
By hand is what I know,
and I know I'd like a better way.
neolitic is offline
Old 01-27-2009, 07:58 PM   #11
Crete Buster's Avatar
Trade: Concrete breaking, sawing drilling - Demolition - Confined Space Excavation
Rewards Points: 75
I am creating this post in response to Neolitic's post. I would not have created it otherwise. (as not to be self promoting) I am the guy from Cincinnati he is referring to. We have electric powered mini excavators that we have used in hospitals, food processing plants, pharmacies and any place where space may be limited and/or fumes can be dangerous. Check out http://www.cretebusters.com and http://mini-equipment.com for more info and let me know if I can be of help. We specialize in confined space excavation and demolition. I'm not sure if this will work or not, but I've attempted to embed a video of one of our recent projects. http://www.youtube.com/watch?v=66Aw__tE0m4 [YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/66Aw__tE0m4&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/66Aw__tE0m4&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
Crete Buster is offline
Old 01-27-2009, 08:02 PM   #12
Originally Posted by Crete Buster View Post
I am creating this post in response to Neolitic's post. .........
So.....
You have "Auto-Notify"
if your name is mentioned?
neolitic is offline
Old 01-27-2009, 08:04 PM   #13
Rewards Points: 75
Yeah I know. I had already started my reply before I saw that you had posted my info.
Old 01-27-2009, 08:06 PM   #14
Rewards Points: 75
There's not much "getting out" in Cincinnati right now thanks to the weather. So I've been in front of the computer most of the day.
Old 01-27-2009, 08:10 PM   #15
There's not much getting out in Cincinnati right now thanks to the weather. So I been in front of the computer most of the day.
Tell me about it.
neolitic is offline
Old 01-27-2009, 09:03 PM   #16
AustinDB's Avatar
Rewards Points: 518
not sure what your problem is...the title of the post was the question and elaborated up in the body If you're complaining that it didn't have a question mark, well, that's just being picky What's next, slamming me for run on sentences or ending a sentence with a preposition
keep it lite baby!
someone posted about the Dingo-I was hoping to get feedback about that unit. I know they have tracks-how is the traction and load capacity?
The mini-excavator looks pretty interesting. I'm guessing it's only used on concrete floors-what is the weight? Would be worried about the speed of the unit-scoop dirt, drive dirt to opening, return for another scoop...
AustinDB is offline
Old 01-27-2009, 10:13 PM   #17
Retired Contractor
LNG24's Avatar
Trade: Contractor
Rewards Points: 538
72,
I am kind of lost too. Let me know if I am wrong.
1) You are replacing the entire foundation
2) You want to dig the basement deeper
3) you are worried about getting equipment under the house?
If I am right, you would jack up the house and rest it on cribbing. You can put it as high as you need it to fit the equipment under there. We can usually get under there with a 30,000 - 40,000lb excavator and a little hand digging.
I have found that its usually easier to leave the existing foundation (if its in good condition and up to todays codes) and simply lift the house up to where you want it. You can add a knee wall on top of the existing foundation or block it up higher.
LNG24 is offline
Old 01-27-2009, 10:38 PM   #18
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Originally Posted by LNG24 View Post
72,
laid 6 courses of tens under one just like LNG24 described this summer, the owner had a house mover lift it.
I think the OP said the foundation wasn't so good
I would think the bobcat would work the best, Is there concrete down there or is it a crawl space?
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 01-28-2009, 07:06 AM   #19
Retired Contractor
LNG24's Avatar
Trade: Contractor
Rewards Points: 538
@dakzaag; Yeah, I kind of got that too, but I am not sure if he was talking the entire foundation.
@72 Still having trouble determining the question, but if it is simply; Will a Skid Steer fit thats easy enough to figure out.
According to the Bobcat website: http://www.bobcat.com/loaders/product_lines/track/t250
T250 Track Steer is 80.9" high(close)
S205 Skid Steer is 76.3" high so either would fit.
However, 2' of soil is not that much to dig by hand. That being said, you won't find me doing it but you will find my guys doing it. Of course they will be like
LNG24 is offline
Old 01-28-2009, 07:33 AM   #20
AustinDB's Avatar
Rewards Points: 518
I'm sorry for the lack of detail guys.
The goal is to use a machine to increase the depth of the crudely laid conrete floor by approximately 2'. Not looking for info on the outer wall dig-that can be done w/ a mini-excavator. The existing floor is broken and somewhat crumbling concrete-likely not laid on a solid base cracked throughout (for easy breaking). It sounds as if a T180 would do the job, digging the additional depth while working toward the interior.
AustinDB is offline
Basement Waterproofing Help eagleandbaby General Discussion 1 10-04-2008 03:41 PM
Return Grill in the Basement orson HVAC 7 10-03-2008 12:01 AM
Basement bathroom Input requested guyute65045 Plumbing 7 09-14-2008 09:43 PM
Floating Basement Walls McMasters Framing 15 08-26-2008 11:43 PM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
