How To Cut 18 Ga Hollow Metal Doors ?
Old 01-06-2018, 08:30 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,866
What's a good method of cutting a comm. hollow core metal door 18 - 20 ga ?
Today I used my clamp on straight edge and sawzall -- shoe against the straight edge. Only had a 8" metal blade. Of course wanders on the lower cut.
Does a 4" sawzall blade work better or what else ?
Have to go back and redo the threshold and cut the door again.
Steve
We Fix Houses is online now
Old 01-06-2018, 08:38 PM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,056
Re: How To Cut 18 Ga Hollow Metal Doors ?
Circular saw.
Inner10 is offline
Old 01-06-2018, 09:10 PM   #3
TheConstruct's Avatar
Definetly circular saw and guide. Could try blade backwards or just spend the money on a good Freud ferrous blade and get a perfect cut.
TheConstruct is online now
Old 01-06-2018, 09:22 PM   #4
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,266
Track saw
Metro M & L is online now
Old 01-06-2018, 09:26 PM   #5
rustyjames's Avatar
Rewards Points: 1,428
If you're only doing a single door and don't want to invest in a metal cutting circular saw blade, a 4" abrasive cutting disc in an angle grinder would work, cutting one side at a time.
rustyjames is online now
The Following User Says Thank You to rustyjames For This Useful Post:
pinwheel (01-06-2018)
Old 01-06-2018, 09:29 PM   #6
Probably operator error, but the one time I attempted that with a grinder there was noticeable wobble in the cut.
Old 01-06-2018, 09:32 PM   #7
I do use a grinder to cut some stuff.
How about running the disc next to a 1x clamped on to the door. each side ?
Steve
The Following User Says Thank You to We Fix Houses For This Useful Post:
rustyjames (01-06-2018)
Old 01-07-2018, 01:52 AM   #8
GC/carpenter
Californiadecks's Avatar
Rewards Points: 2,624
I would use a metallic guide vs. a 1x
Mike.
_______________
Californiadecks is online now
The Following User Says Thank You to Californiadecks For This Useful Post:
pinwheel (01-07-2018)
Old 01-07-2018, 06:15 AM   #9
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,062
Mike.
_______________
That's how I've done it. Scrap of angle iron clamped to the door & ran the abrasive blade against it.
pinwheel is offline
The Following User Says Thank You to pinwheel For This Useful Post:
Californiadecks (01-07-2018)
Old 01-07-2018, 02:15 PM   #10
tgeb's Avatar
Rewards Points: 252
Your typical everyday carbide tipped circular saw blade will cut through the light sheet metal of a door with no problem.
The blade won't last too long but if your only cutting one there is no point in getting a dedicated metal cutting blade.
I found out the blades cut steel pretty well while using a wheelbarrow for a cutting table while building some form work.
www.gebcon.com
tgeb is online now
The Following 8 Users Say Thank You to tgeb For This Useful Post:
Californiadecks (01-07-2018), greg24k (01-10-2018), Inner10 (01-10-2018), KAP (01-07-2018), paul100 (01-07-2018), Rio (01-07-2018), Tinstaafl (01-07-2018), We Fix Houses (01-07-2018)
Old 01-07-2018, 03:10 PM   #11
avenge's Avatar
Rewards Points: 2,568
Circular saw one side at a time, last thing I would use is a sawzall there's no controlling the end of the blade.
avenge is online now
Old 01-07-2018, 05:31 PM   #12
Thanks for the help.
Steve
Old 01-10-2018, 08:34 AM   #13
This space for lease
RangoWA's Avatar
Trade: Tool jocky
Rewards Points: 2,066
A good carbide tipped circular blade is a worthwhile thing in your arsenal. I'd bust out a few duckets and get one if you don't have one. I've used them in my cabinet saw cutting aluminum stock, often 1/8" and sometimes 1/4". I've cut tons of the stuff with the same blade without sharpening.
RangoWA is offline
Old 01-10-2018, 08:48 AM   #14
Inner10's Avatar
Aluminum cuts like wood, steel is a little more nasty, I think the rake angle on the teeth is different for steel vs non ferrous. For $50 grab the proper blade instead of shortening the life of a good wood blade.
Inner10 is offline
Old 01-10-2018, 02:44 PM   #15
RangoWA's Avatar
Trade: Tool jocky
I dedicated a blade for metals. 1/4" aluminum cuts slow so I think it would do 18 steel. One thing to watch for with a dust collector though is to disconnect it for steel and maybe a dust bag. The embers can sit for a while and ignite wood dust, heard a few horror stories.
RangoWA is offline
Old 01-10-2018, 06:28 PM   #16
Inner10's Avatar
Al likes to weld to the carbide, the only way I found to route Al frames and doors was to wax around the template before cutting.
Inner10 is offline
Old 01-10-2018, 08:53 PM   #17
rrk's Avatar
Rewards Points: 646
I met a guy a few years ago who was cutting a steel fire door in a condo with a side grinder. Sparks everywhere, he was cutting in the hallway, over carpet and I was walking past him with the building inspector. Who asked him what the hell he was doing.
Did not go well, he had to replace the door, a lot of carpeting, and a lot of wallpaper. Those sparks melted into the carpeting and the vinyl commercial grade wallpaper. The condo association was not pleased.
rrk is offline
Californiadecks (01-10-2018)
Old 01-10-2018, 09:21 PM   #18
GC/carpenter
How some people get by in life is beyond me! SMFH!
Old 01-10-2018, 10:04 PM   #19
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 5,393
14" Demo saw with carbide blade rated for demo saw use...
Water cooling...
I've cut a dump truck box in two in less then 5 minutes...
Different grades/sizes of abrasives are available for differing gauges of metal cutting..... too fine and they go dull on thick material, cut rough on to thin of metal with too large of grit.
Cut door away from carpets......
Fouthgeneration is online now
Metal doors Mike- Remodeling 27 03-09-2012 02:43 AM
Exterior Metal Doors Sprtman Painting & Finish Work 6 02-26-2012 05:10 PM
HD Pre-Hung Hollow Core Doors CookeCarpentry Carpentry 32 01-12-2010 10:10 PM
Hollow metal welded frames welded into structual steel detroit687 Commercial Construction 1 09-11-2008 11:18 PM
Metal Doors skolson Painting & Finish Work 13 05-29-2007 06:03 AM
