Hollow steel lally or concrete filled?
I am going to be builing a small garage (16'x20'), that will have a concrete roof that will double as a patio above for the owners.
I am going to have corrugated decking sheets under the concrete
supported by I-beam(s).
Should I support the beam(s) with hollow steel lally posts or concrete filled ones? Also, there is an existing 10'x20' slab that I will add the additional 6' to. Where the posts will come down is on the existing slab. Should I cut out a 2'x2' section of the existing slab under the posts to allow me to pour a footer, or can the posts rest directly on the existing slab?
I am thinking I will need solid footers under the posts just because of the weight of the concrete, steel, beam, people load, and furniture load thay may all be on it at once.
