Trade: Former Electrician
Holes In My Foundation Wall
I have a bunch of holes around the outside of my foundation. It seems that the bees have now discovered them, and are starting to setup shop. Is this just a result of poor workmanship or something else. It appears that it may getting worse as time goes on. Should I be concerned about this and if so who fixes this sort of thing? Photos included.
Thanks Rob |
Trade: Residential General
Re: Holes In My Foundation Wall
Nothing to be concerned about. They are simply small voids. A little too high of a water to cement ratio on the mix probably. You can patch them if you want to keep the bees out.
Thanks for your quick response. last year I didn't pay any attention to it, but this year the bees seem extra aggresive. Maybe they knew I planning to get out the spray once they were in for the night.
Rob |
Yet another carpenter
Trade: Carpenter Woodworker
Clean em out and patch em with hydraulic cement.
Carpentry and Woodworking - Chicago / North Shore - Ted's Carpentry "I don't know everything but at least I think I do, and that's what really matters."
It's all about the Avatar
Trade: I have no face!
I have seen concrete do that when chucks of ice get into the mix, it looks like other debis may have been used as aggregate.
Your mix is only as strong as the aggregate. Sticks and crap do not have much tensile or compressive strength when compared to rock
Trade: Marketing
I would just patch them over with some concrete patch compound.
#7 | |
Priced In
Trade: Exiled For Life
Re: Holes In My Foundation WallQuote:
Water to cement ratio has nothing to do with it. That is caused from over stinging with the vibrator. Over vibration will cause air pockets. This is nothing to get concerned about like rock pockets. Just sack the pockets and forget about it. All you need is a bag of grout and some sand nothing fancy which is a waste of money. Give it a 3 to 1 ratio of grout and sand mix it a little dry with water and you have a perfect mix. Smooth is out with a margin trowel and be done. |
Trade: Masonry consultant
Nothing structural.
I see three different cosmetic problems that can be patched by anyone. I also see some possible problems that were patched earlier. Some possible aggregate quality problems in the concrete. Built in the winter or just the usual quality problems with residential poured walls?
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
The one with rebar showing should be cleaned with Phosopho before patching.
| Backfilling a foundation wall | barbie13607 | Masonry | 7 | 10-07-2007 05:08 PM |
| Holes in ext. cement wall | bujaly | Construction | 14 | 12-18-2006 11:26 PM |
| Water seepage thru concrete foundation wall | Rrooster | Construction | 17 | 11-24-2006 01:05 PM |
| foarming foundation wall | bright star | Masonry | 5 | 09-29-2006 02:17 AM |
| Foundation wall | Glasshousebltr | Construction | 15 | 05-11-2006 11:40 PM |
