HELP!!! - Poorly Framed Wall - Page 2 - Construction - Contractor Talk
Old 12-13-2008, 08:41 PM   #21
Al Smith
A W Smith's Avatar
Rewards Points: 1,000
Re: HELP!!! - Poorly Framed Wall
take a look at that photo again. the header which I am assuming is a triple 2 x 10 spans less of a distance between those two roof planes than a floor to ceiling 5 inch deep microlam would go floor to ridge. seems to me if you cut that header and insert vertical microlams you would be making the problem worse not better. Call an engineer.
also what home depot did those toy plastic horses come from? get some real ones.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 12-13-2008, 10:27 PM   #22
Young Gun
HallisseyDesign's Avatar
Trade: Smartass
Rewards Points: 250
Go to a steel place have them make you 5- 20 foot long 6 inch wide by 1/2 inch in depth. Put bolt holes in it every 10 inches and then add nail holes every 2 inches side by side all the way down. Then span them from the top to the bottom. Then run 5/8 cdx 4 ply on it and dado out were the steel is. Then you have a really strong wall and also smooth for the rock to go on.
HallisseyDesign is offline
Old 12-13-2008, 10:49 PM   #23
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
in the past when ive framed walls such as this the engineer always spec'd 2x8 timberstand for studs as opposed to 2x6, for windows on top of one another we would have the upper header bearing on a double jack then the lower header bearing on a single jack the outer most being a continious jack down to the plate,
also anytime a king stud and jack met a plate or header L-70 hangers were used
the header would ger two per side , one to the king and one to the jack , and plywood
the last one i did i got screamed at by the project manager for using timberstrands for my jacks along with cripples and sils, he wanted spruce used. oh well, guess i built the wall too expensive, expensive but strong
woodworkbykirk is offline
Old 12-14-2008, 12:28 PM   #24
Higgs's Avatar
Trade: CE Project Engineer
Rewards Points: 150
granted i havent read though all the posts, would it be possible to creat a bracket that whould connect the 20' 2x6 to the framing above the header. make the bracket out of 1/4" steel and bolt to the framing with lag blots.
Higgins
"The more we sweat in peace, the less we bleed in war."
-- Vijaya Lakshmi Pandit (1900-1990)
Higgs is offline
Old 12-14-2008, 01:08 PM   #25
orson's Avatar
Trade: Kitchen & Bath
Rewards Points: 502
I'm still not seeing the issue with the wall as it's framed. What is this talk of a hinge point? I see a gable set on top of a wall... I see this every day. Are you saying the gable is going to magicaly fold in half around a vertical center point? The roof sheathing provides rack bracing so the gable and tusses can't topple, so how is the gable hinged?
The header is sitting on top of jacks and the weight of the gable is on the header...what's the problem?
I would be more concerned about the wall if it had been framed with king studs or steel running verticaly from floor to ridge. That 2x10 header is giving the wall needed rigidity, the major thing I would have liked to see done different is a double top plate on top of the 2x10 header to stiffen the wall up horizontaly.
orson is offline
Old 12-14-2008, 03:35 PM   #26
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
I had this problem once. There was a door in our wall and once we had the wall framed we showed the HO that the whole wall shook a bit...even though we ran full length 2x6 studs. So it would be bad once completed, if you ever closed the door hard.
The cheap fix (HO was into saving $$$ - imagine that) was to build a 24" knee wall and install it horizontally, as a plant shelf, at the triple 2x10 height, making it span the entire room. Then plywood it with 3/4" cdx on both top and bottom, glued and nailed 4" o.c. Throw in some gussets / corbels and blam.
Voila...plant ledge...wall stiffener.
(Dust collector too)
wallmaxx is offline
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 06:16 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 10:27 PM
moving centennial wall stacker Masonry 4 10-19-2006 11:12 PM
Repairing Jog In Wall for Stone Nailbird Windows, Siding and Doors 0 07-20-2006 05:58 PM
Low (12" or so) brick garden wall questions bindersbee Masonry 8 04-27-2006 07:31 PM
