HB&G Permacast Help
Old 06-29-2008, 10:22 AM   #1
Agolk2's Avatar
Trade: Insurance Restoration and Remodeling Contractor
HB&G Permacast Help
Hey all,
I'm trying to use HB&G Permacast columns as the supports for a beam on a freestanding deck (attached to house but not bearing). Anyone know the best way to anchor these to footings and to connect the beam to the top of them? Only used them in wood to wood applications before.
Thanks,
Andrew
Andrew Golkin
ANG Visuals
www.ANGVisuals.com
(703)898-4430
Agolk2 is offline
Old 06-29-2008, 11:21 AM   #2
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
Re: HB&G Permacast Help
I just predrill the bases and use a TapCon.
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 06-29-2008, 11:35 AM   #3
Agolk2's Avatar
You mean screwing brackets into the column and then using tapcons to attach those brackets into the masonry footing?
Andrew Golkin
ANG Visuals
www.ANGVisuals.com
(703)898-4430
Agolk2 is offline
Old 06-29-2008, 12:30 PM   #4
Professional Instigator
rbsremodeling's Avatar
I would attach base first with tapcons like Jason said then cut the column and slide it into place.
rbsremodeling is offline
Old 06-29-2008, 12:42 PM   #5
Agolk2's Avatar
Oh OK, for some reason I thought the base on those permacasts was just trim and not structural.
Am I wrong about this?
Andrew Golkin
ANG Visuals
www.ANGVisuals.com
(703)898-4430
Agolk2 is offline
Old 06-29-2008, 12:46 PM   #6
Restoration Crazy
The base and the capitals are what holds the columns from shifting from side to side. I wouldn't run a screw into the column itself because you could ruin the structural integrity of the columns by weakening it with holes from the screws.
Facebook | Twitter
Old 06-29-2008, 12:51 PM   #7
Honestly I not sure. But I would assume they are structual since the column sits on or in the bases, they would transfer the weight of the deck to the column. Even though the bases are referred to as ornamental features. I am sure someone smart than me will be around with a better answer
Old 06-29-2008, 12:53 PM   #8
Agolk2's Avatar
Ok, now I understand. So for the cap connecting to the beam.....screw or lag those into the (3)2x10 beam bearing on it?
Andrew Golkin
ANG Visuals
www.ANGVisuals.com
(703)898-4430
Agolk2 is offline
Old 06-29-2008, 12:54 PM   #9
Restoration Crazy
One other thing; I usually cut my column to size, slide the base and capital over the column, move the column into place, and attach the base and capital.
If you have several in line with each other, set them to a center mark rather than a string line. These columns vary in shape and size. If you string one side, the opposite side will look out of whack. Best to snap a center line along the row and trust that line.
Facebook | Twitter
Old 06-29-2008, 12:57 PM   #10
Restoration Crazy
Yup, thats about it. I wouldn't call them structural, but rather a trap that keeps them from sliding around. The column itself is what holds the weight from above.
Caulk around the base and capital to the column but not to the floor. Let water come out at the bottom should the caulk joint ever fail. Use a good sealant with plenty of flexability. I would use DynaFlex, not painters caulk.
Facebook | Twitter
Old 06-29-2008, 01:01 PM   #11
Yup Jason got you on the right track.
I see you are in DC. Do you want me to run the calcs, size the columns and install them for you too
Old 06-29-2008, 01:04 PM   #12
Agolk2's Avatar
Would be open to it, as long as the contractor is OK with you taking a good chunk of his profit
Andrew Golkin
ANG Visuals
www.ANGVisuals.com
(703)898-4430
Agolk2 is offline
Old 06-29-2008, 01:05 PM   #13
Agolk2's Avatar
Thanks to Jason as well.
Andrew Golkin
ANG Visuals
www.ANGVisuals.com
(703)898-4430
Agolk2 is offline
Old 06-29-2008, 01:07 PM   #14
Email me when you get a chance and I will put your info in my rolodex rory@rbsremodeling.com
Old 06-29-2008, 01:08 PM   #15
Agolk2's Avatar
RBS, I do work with contractors in the DC, VA, MD area, send me an email at agolk2@gmail.com -- we could give each other some work I'm sure.
Thanks,
Andrew
Andrew Golkin
ANG Visuals
www.ANGVisuals.com
(703)898-4430
Agolk2 is offline
Old 06-29-2008, 01:37 PM   #16
Email sent Andrew
Old 06-29-2008, 03:32 PM   #17
BUILDER / REMODELING CONT
buletbob's Avatar
Trade: Builder/Remodeler
Here what I have done in the past. Just thought I throw it out there, I took some 5/4 ACQ and cut it the same dia. as the inside of the post just shy 1/4" and screwed it down to the deck and then laid the column over it to help give it some support from kicking side to side. I have seen some BRATS! grabbing them and swinging around, just did not want to put all my faith in the base's being the only thing holding them in place. Don't want to wind up with a letter from there Lawyer if you know what I mean.
Quality is remembered long after the price is forgotten
buletbob is offline
