HardiPlank Over Cedar..?
Old 02-04-2010, 03:33 PM   #1
BuckleyBuilt
buckleyclan's Avatar
Question
Hey Ya'll,
I am starting a rebuild of sorts soon and have some questions.
The garage had to be re-trussed due to snow load failures.
My part of the job is to side from the wall-to-truss transition, all the way up to the peak of the gable end, and install soffits all the way around.
The architect/eng specified HardiPlank for siding so I am essentially starting where the existing cedar siding stops and continuing up.
  1. What should I do, if anything, at that transition from cedar to hardi?
  2. The A/E spec'd sheathing the gable end in 3/8" osb prior to siding.Hardi states that you need 7/16 to nail to. Do you think that the 1/16" thinner sheathing will transfer more ripples/waves in the appearance or that it will provide too little purchase?
Thanks for your feedback.
You can't direct the wind, but you can adjust your sails!
buckleyclan is offline
Old 02-04-2010, 07:07 PM   #2
Tom Struble's Avatar
Trade: siding
Re: HardiPlank Over Cedar..?
you got all those nice studs to nail into,thats the best for hardie
Tom Struble is online now
Old 02-04-2010, 08:07 PM   #3
RadRemod's Avatar
You could install and flash a Band board. But thats normally used for changing siding types and that might not look asthetically correct there since your going lap to lap.
As for the 3/8" osb I'd use whatever makes the transition smother. However, make sure all your nails hit the studs and joints too.
RadRemod is offline
Old 02-07-2010, 03:46 PM   #4
M. A. Hansen Construction
M. A. Hansen Co's Avatar
Trade: Commercial Contractor
I take it they want hardi because of the cost of cedar! If you are really worried about the plywood I would use CDX over OSB and nail your hardi to the trusses using a ring shank nail even though Hardi recommends a smooth shank nail.
M. A. Hansen Co is offline
Old 02-07-2010, 04:06 PM   #5
topsail's trimcat
woodworkbykirk's Avatar
sounds good to me, i always nail to studs with harti or clapboard indirectly, we foam all our walls then put nailing decking to the studs to create our rainscreen then nail siding to that
woodworkbykirk is offline
Old 02-09-2010, 02:16 AM   #6
BuckleyBuilt
thanks for the input.
We are going with Hardi since that's what the A/E has on the approved plans.
In rural areas of CA, we are not allowed to put any siding, overhang, roofing, etc that is not class A fire rated, even when rebuilding an existing structure.
It's all about the wildfires.
Leave it to stupid CA to regulate the construction industry, rather than spending some of our tax dollars on thinning the dang forest...
Old 02-09-2010, 04:43 AM   #7
wheeler's Avatar
Trade: design / build defense contractor
ban board the transition. suggest a mockup w/trim details
wheeler is offline
Differences between GP Cedar Spectrum and CT Cedar Impressions Dcislander Windows, Siding and Doors 42 08-03-2010 07:28 AM
What would you quote to build this cedar greenhouse (ballpark) photogoat Green Building 39 06-23-2009 02:45 AM
staining new cedar white world llc Painting & Finish Work 2 02-12-2009 07:58 AM
joist centers using 3/4" cedar Old Sawdust Decks & Fencing 32 12-02-2008 09:52 PM
Pressure treated and cedar pfloyd Decks & Fencing 4 05-31-2008 12:46 PM
