Gravity Drainage Basement Systems
Old 08-01-2007, 08:56 PM   #1
skidmark845's Avatar
Trade: carpenter
What's everyone's opinion on GRAVITY drainage basement systems vs. standard sump pump drainage? Anyone ever heard of any issues with the gravity systems? (Ex: freezing at exit points, etc)
skidmark845 is offline
Old 08-01-2007, 09:10 PM   #2
mickeyco's Avatar
Trade: Squirrel Handler
Re: Gravity Drainage Basement Systems
I'm in my first house with a sump pump, everything before had gravity drains to a catch basin, then out to city sewers. I'm not a big fan of sumps, out here the power goes out every time there's a storm, when you really need the pumps. Had a few back-ups (catch basin needed cleaning) in the places with gravity drains (make sure to have a stand pipe), no problems freezing, one was outside the back basement door, exposed to the weather but down below the frost line. The one advantage I had was that my prior homes were higher than surrounding areas so we never had flooding issues.
I don't know if you can put some sort of check valve on them, but I think that would help with any flooding worries, the plumbers here should know.
mickeyco is offline
Old 08-01-2007, 09:27 PM   #3
Trade: carpenter
What's a stand pipe? Also, why would the catch basin need to be cleaned since it is supposed to have a lid?
Old 08-01-2007, 09:47 PM   #4
mickeyco's Avatar
Might be the wrong term but a stand pipe is something (a long length of pipe) you stick in the drain vertically when you're expecting water or going to be gone for a while. A catch basin does have a lid, but what does that have to do with cleaning them out? Over the years you would get a sludge build up on the bottom below the exit to the city sewer and you call out the honey wagon to clean them out.
mickeyco is offline
Old 08-01-2007, 10:20 PM   #5
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Daylight footer drains are always the best. Just gotta make sure that there are no obstuctions at the end of the pipe. I have actually seen tree roots grow into the end and back the water up into the basement.
Sump pumps should only be a back up, not a primary footer drain.....unless daylight is not applicable. If a sump pump is the only footer drain system, then a battery back-up should be installed.
rino1494 is offline
Old 08-01-2007, 10:22 PM   #6
concretemasonry's Avatar
Trade: Masonry consultant
You obviously try to put in a gravity system for the discharge (to "daylight") if the terrain permits. In our area (Minnesota) freezing is not really a problem with most installations. The backfill around the discharge live has a large capacity to store water and heat. Despite cold temperatures, if the is any snow cover, the ground will not freeze as deeply as you would be required for buildings. A good installation has a dicharge that is not visable and is protected. - Pumped discharge to the exterior suffers even more problems unless the line is burried to the same extent.
Few municipalities permit dischrge of sump water into sanitary sewers.
A sump system can be very reliable if you have a battary back-up or a spare on the shelf.
Remember - any ground water that you collect has heat that can be used to prevent freezing if the discharge is not out in the open.
Dick
concretemasonry is offline
Neighbors wall allowing drainage into my yard Team Scream Masonry 20 11-04-2007 02:05 PM
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
Wooden Basement? LWF Construction 21 05-08-2006 04:17 PM
Landscape solution to basement moisture problem RJC Construction 3 11-21-2005 01:34 AM
