Glass For Loft Floor
Old 11-17-2017, 06:48 AM   #1
Fine Handcrafted Opinions
Bearded Wonder's Avatar
Trade: General
Rewards Points: 1,204
I have a customer who wants to fill in a 4í x 7í space off of his second floor loft with a glass floor. I donít have a picture of the space, but it would be really cool for where he wants it. It has walls on 3 sides, and the current loft edge on one of the 7í sides with railing. We want to remove the rail, fabricate a steel frame that would be bolted to the framing on all four sides, and install a glass floor flush with the existing loft floor, and this will create a space for a desk. So definitely will be a live load on this glass floor, and needs to be done properly.
I have the logistics of the frame covered I think, I have a guy who can engineer and fabricate it, and my guys can install it. My problem is the glass. I obviously need someone who can design/ engineer structural glass for this space and a live load, I canít have anyone just winging it.
I have two glass companies trying to source it, and neither is doing well. Apparently itís not a terribly common request. One sent me a semi vague email after hours yesterday showing $6250, and Iím not sure if thatís glass only or installed, although I expect a follow up call this morning to explain it. Seems a bit high, but I really have no clue if it is or isnít. The other is still trying to come up with something from their source.
Does anyone have any insight into this? Any glass companies in the DFW area that do this type of thing? Any ideas on feasibility, or general advice from having done something similar? I think itíd be a cool project, and seems pretty straightforward if I can source the glass and confirm that the frame and glass are compatible. Should I avoid this job like the plague due to potential safety issues?
Thanks
Sent from my iPhone using Tapatalk Pro
Bearded Wonder is online now
Old 11-17-2017, 06:55 AM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 10,701
Re: Glass For Loft Floor
No idea, but I vaguely recall reading they use laminates for this sort of thing.
This was in the news recently. I wonder what they used.
MarkJames is online now
Old 11-17-2017, 11:18 AM   #3
Trade: General
Iíll see your skywalk and raise you a cantilever...
Old 11-17-2017, 11:37 AM   #4
Frank Castle's Avatar
Rewards Points: 276
I like the idea.
But,
Why put in a "sky light" in and then cover it with a desk?
Who wants to look up from below and see the underside of a desk?
The sliding/rolling movement of the chair alone will fubar the glass/acrylic floor.
Just my .02Ę
Adapt, Improvise, Overcome.
Frank Castle is offline
The Following User Says Thank You to Frank Castle For This Useful Post:
TimNJ (11-17-2017)
Old 11-17-2017, 01:27 PM   #5
Trade: General
Originally Posted by Frank Castle View Post
I like the idea.
But,
Just my .02Ę
Well itís kind of a modern looking interior town home, a bit minimalist, and I believe the desk and chair would be a small setup on one side, not some big oak antique rig with a massive 8 wheeled wooden chair.
Chair would be small also and have to have either rubber wheels or no wheels, and pads.
I think it would actually be really cool in their house.
Old 11-17-2017, 01:56 PM   #6
Rewards Points: 276
Sounds very cool. Would like to see that when it's done.
I would just worry the chair wheels/pads (any type) will eventually leave the glass/acrylic looking fogged underneath it.
My desk chair is on basic office plastic wheels. It was on painted concrete for a while. Wore the paint off the floor. That I kinda expected.
Now it's on regular smooth concrete, and you can definitely tell where the chair rolls around all the time.
I'm sure different wheels would make a big difference for my set-up. But I'm guessing sooner or later something will scratch it.
Often something gets stuck to my boot tread and travels into my office area(usually a rock). Unbeknownst to me, it falls out of the boot tread, and then I roll over it with the chair. Wheel stops dead, pushes rock over a little bit, leaves a nice mark on the concrete floor.
Again, just my worry.
Good luck, and please report back on how it turned out with finished pics.
Old 11-17-2017, 03:43 PM   #7
Designer/Contractor
Rio's Avatar
Rewards Points: 446
Here's a company we were going to use awhile back, ran into problems with the building department but the company and product looked pretty good.
http://www.ibpglassblock.com/glasswalk/
Rio is online now
The Following 2 Users Say Thank You to Rio For This Useful Post:
Bearded Wonder (11-17-2017), Sisyphus (11-18-2017)
Old 11-17-2017, 09:27 PM   #8
Talking Head
EthanB's Avatar
Rewards Points: 12
Should have it specified by an engineer. No reason to avoid the project but you definitely don't want to be the one on the hook for the design and specification.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
Old 11-18-2017, 06:37 AM   #9
builditguy's Avatar
Rewards Points: 120
I can't help you. I know it can be done. I know a house that has a glass area on the second floor. May be Acrylic, I don't know. I know it's see through.
I remember because another customer knew about it and said, "If I'm there, in a dress, I'd better remember to wear underwear."
builditguy is online now
Old 11-26-2017, 03:58 PM   #10
stephyaurora's Avatar
Trade: glazier
Rewards Points: 4
I know this response is a little late but I just joined. We constantly do this type of work in my area and we use triple laminated/tempered glass. Any type of glass that will be walked on has to be laminated for safety reasons. If you have not found a manufacturer yet, DO NOT get it from a company that installs as well because they will KILL you on the price of just the glass. You actually are in a great area to get glass more locally like this, I have had it shipped up several times from TX, Mexico, and LA to NY. Also, if you are doing a glass floor I would 100 % go with a starphire/low iron glass or KrystalKlear, when you layer regular glass it gets soo green it looks like kryptonite. If you are still looking for a fabricator, let me know. I can give you quite a few. Also with framing, the amount of layers will be depending on the PSI. If its made right its strong as hell but framed wrong, its just fragile glass.
stephyaurora is offline
The Following User Says Thank You to stephyaurora For This Useful Post:
builditguy (11-30-2017)
Old 11-28-2017, 10:24 PM   #11
Designer/Contractor
Rio's Avatar
Rewards Points: 446
That website I listed above has engineers on staff and they review and approve the installation, been quite a while since we looked into it but I seem to remember that each project was 'custom' and thus very expensive although what shut us down was they didn't have some certification required by the AHJ here.
Rio is online now
Old 11-30-2017, 06:18 AM   #12
builditguy's Avatar
Rewards Points: 120
Good post. This is exactly what we need. Good quality, helpful information.
When I posted, i said, "I can't help you". You can help. That is great.
Thank you.
Shower glass options gbruzze1 Kitchens & Baths 4 03-06-2017 02:58 PM
Need recommendations to fix newly but poorly finished concrete floor MikeGC Concrete & Paving 20 03-08-2014 07:11 PM
degreasing garage floor - prep for carpet MarkJames Flooring 5 03-25-2013 10:59 PM
FS: Panther Floor Stripper Scraper 6280 HD Allfloorremoval Contractor Swap 1 07-16-2012 09:45 PM
floor finish Pete'sfeets Painting & Finish Work 6 05-16-2012 08:14 PM
