Framing Deck To Support A Hot Tub
Old 08-20-2011, 09:09 AM   #1
A&J's Avatar
Trade: Renovations
Looking for a footing layout and sizes to support a 8 person hot tub. Are 2x6 joists usable in this application?
A&J is offline
Old 08-20-2011, 10:25 AM   #2
WildWill's Avatar
Rewards Points: 504
Send a message via MSN to WildWill
Re: Framing Deck To Support A Hot Tub
I found this, maybe it will help.
http://webcache.googleusercontent.co...www.google.com
WildWill is offline
Old 08-20-2011, 10:37 AM   #3
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 20
Generally NO & almost every member here is going to refer you to see an engineer.
Just a little common sense thinking - how many liters at how much weight + 8 people at how many kilos - that adds up pretty quickly
SLSTech is offline
Old 08-20-2011, 10:38 AM   #4
Ash@OTL's Avatar
Trade: remodeling/ home repair
Rewards Points: 160
The last time I did a hottub deck I used 6 x 6 posts with 12" wide by 48" deep footers. Framed with 2 x 10, joist hangers, and for added support lag screws into all joists.. Decked with 2 x 6. It came out solid as a rock.
Ash@OTL is offline
Old 08-20-2011, 11:36 AM   #5
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 854
There is no prescriptive solution for a deck with a hot tub, you need it designed I think.
Andy.
ScipioAfricanus is offline
Old 08-20-2011, 11:57 AM   #6
KnottyWoodwork's Avatar
Trade: Trade work for money.
Rewards Points: 512
Do you have the oppertunity to drop it in the deck, instead of on? If not, give those techno posts a look.
KnottyWoodwork is offline
Old 08-20-2011, 12:16 PM   #7
Fine Deckbuilder
Clemens's Avatar
Trade: Deck business
Rewards Points: 250
A hot tub platform is normally designed freestanding. (if elevated)
This means a minimum of two beams (2 2x12) sitting on 6x6 (notched) with 20" x 8" footings. Joist a minimum of 2x10 16"o.c. with 2x6 decking.
Joist shouldn't sit in joist hangers but rather on top of beams.
This is common in our area (engineered plans)
You need to see an engineer for plans (like it or not) and give him the specs.
Don't even think about 2x6 joist.
Clemens
www.finedecks.com
Clemens is offline
Old 08-20-2011, 12:33 PM   #8
GettingBy's Avatar
Rewards Points: 6,486
Knowing the dims of your tub you can figure out how much it weighs using 62 pounds/cu. ft. of water.
I guess it's a distributed load rather than a concentrated load.
The calc. from weight and dims to a lumber grade & size & spacing is easy but tedious.
E.g., 500 gals x ~8#/gal = 2 tons.
4000#/64 sq. ft. = ~63 PSF dead load.
The Engineering Toolbox website and others have the formulas.
After you build it, check the joist deflection under the tub, L/360 or L/720 or whatever is recommended for decks.
Designing footings can be messy
http://books.google.com/books?id=_mf...page&q&f=false
but rules of thumb or testing can get you pretty close, I'd think.
If you hire an engineer you will pay more for his fee but spend less on materials and you will worry less. This, because non-engineers who are not so certain tend to overdesign and overbuild and may still worry about the safety of the finished product.
GettingBy is offline
Old 08-20-2011, 02:55 PM   #9
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Rewards Points: 2,000
train driver
Winchester is offline
Old 08-20-2011, 03:48 PM   #10
Brett Ashworth
FrehouseRemdlin's Avatar
Trade: Remodeling, Additions, Repairs
Rewards Points: 75
Clemens
www.finedecks.com
This is how I did my last one, turned out rock solid! I'll see if I can find some pics.
FrehouseRemdlin is offline
Framing wrap around deck with a 45 corner ryanh Decks & Fencing 44 07-03-2010 11:48 AM
questions about framing a ground level deck dvatt Decks & Fencing 29 06-10-2010 08:24 AM
Framing Safety Safety Guy Tools & Equipment 3 08-13-2009 09:46 PM
Can I cantilever an extension to an existing deck? lot249 Carpentry 9 05-23-2009 01:27 PM
cantilevered deck framing robert c1 Decks & Fencing 8 08-08-2008 10:11 AM
