Footing Drain Question
Old 09-02-2007, 02:54 PM   #1
chrisk's Avatar
Trade: renovation
I'm doing a garage addition on a slightly sloping small city lot in Seattle. The garage floor slab will be at finish grade and the footing is 18" below the top of this slab. Must a footing drain be installed along the footing or can it be installed at or below the basement slab along the foundation wall? If it is installed at the footing I can not drain to daylight, but if it is installed along the wall just below the elevation of the slab i can drain to daylight.
Thanks for your help,
Chris
chrisk is offline
Old 09-02-2007, 03:14 PM   #2
tgeb's Avatar
Re: Footing Drain Question
I'd say you will be fine installing it as you are talking about, (just below the level of the slab), I would back fill and compact the soil to the level you want the drain so that you don't have water hanging out in the stone that would be below the level of the day-lighted pipe.
www.gebcon.com
tgeb is offline
Old 09-02-2007, 04:55 PM   #3
Captain of the Titanic
Vinny's Avatar
Trade: Asphalt Paving,Excavating, Masonry
Chris
I'm not sure I understand here. You dont need a footing drain for a slab and foundation to footings since there is no basement.
If you are refering to the adjacent house basement you are attaching to then yea, I geuss it would be ok to put the pipe just below the slab as the max water hieght will be captured by the pipe prior to entering the basement but just as a reminder, the lower the better.
Roccies Asphalt Paving
The Right Way Driveway Company
If you say you cant, your a loser. If you say you wont, your a quiter. Which one do you want to be?
Vinny is offline
Old 09-02-2007, 05:05 PM   #4
Forry's Avatar
Trade: General Contractor, Remodeler
Don't know the regs. in Seattle, but in Eugene, Or. we also get tons of rain, and the city won't let us drain the perimeter to daylight, we have to drain to the city storm sewer, ie. the street. if it's not possible to drain to the street, we have to have a drywell engineered. I'd check with the city about code requirements.
Forry is offline
Old 09-02-2007, 06:30 PM   #5
chrisk's Avatar
Trade: renovation
the slab is at grade at the entrance but the other end will be 36" below grade... so the garage cuts into the slope.
chrisk is offline
Old 09-02-2007, 07:08 PM   #6
tgeb's Avatar
So are you saying that you have foundation below grade, but above the slab in the rear and side but not the front?
I would make sure those walls are waterproofed and proceed as outlined previously, as long as all of your drain is below slab height, and be sure to comply with local code.
www.gebcon.com
tgeb is offline
Condensate drain question airwick HVAC 6 07-23-2007 07:48 PM
Stupid Question about drain holes in built up walk Jacey Concrete & Paving 6 04-01-2007 04:53 PM
French drain question 72chevy4x4 Construction 4 11-01-2006 10:46 PM
drain tile question bobbrown Construction 5 09-05-2006 07:52 AM
