Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction
Old 11-12-2008, 05:11 PM   #1
Trade: General Commercial Construction
fireproofing
Fireproofing sparyed foam
Hi, I was hoping someone here knew a definite answer to this question or a place I can find one.
Building:
A commercial building 1 story, flat roof, metal deck, structure is steel. The exterior is drywalled and the air/vapour barrier is applied onto the outside of the exterior drywall. The roof is a rubber membrane.
To complete the insulation a spray foam was used on the steel that supports the roof at the top of the walls. The walls are not rated wall on the inside. On the interior the drywall is 3/4" shy of the decking to allow for deflection. This leaves a 3/4" gap of exposed foam.
The foam is Polar Foam 7300
Does this foam need to be fireproofed?
Thanks for any help.
canuck is offline   Reply With Quote
Old 11-12-2008, 07:33 PM   #2
Ivinni's Avatar
Trade: High Rise Caulk and Insulation
Assuming you are on IBC 2003 or later, the insulation guys didn't do you any favors. That is unless there is a UL fire rated system that has been published for use in structural steel fire protection.
I do not know of a foam that is used for that purpose, but I ma in the firestopping end and only cross over to fireproofing occasionally for patch work.
Are the sides of the beams and/or any other part of the structural steel fireproofed?
Do the plans call for the steel to be protected?
its not going to get better with straps, or new footings or even aroma therapy.
Ivinni is offline   Reply With Quote
Old 11-13-2008, 08:04 PM   #3
As far as I know there is a req. for a flame spread <25 for any material in an air plenum. The NBC states any foam must have a flame spread rating <500.
Doesn't the Code for the air plenum trump the one for sprayed polyurethane foam?
Old 12-01-2008, 07:16 AM   #4
is the foam orange? that's the fireproof rated stuff in the states. don't know the rating on it though.
72chevy4x4 is offline   Reply With Quote
Old 12-01-2008, 07:25 AM   #5
Trade: Plumbing & Gas Contractor
I haven't used the foam but often times am required to use a caulking ,red in color called 3600EX Firestop.
threaderman is offline   Reply With Quote
Old 12-01-2008, 11:25 AM   #6
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
I used to inspect fireproofing on commercial buildings as a special inspector. And the ones I've done had a thickness specified for each member on the plans. So I had to measure and verify the thickness on each spot.
But that's how it's done on the high rise buildings in Seattle. Sorry, I have no idea what flame spread <25 or <500 means in Alberta. Ask your building department?
KennMacMoragh is offline   Reply With Quote
Old 12-02-2008, 07:39 PM   #7
Thanks for the suggestions.
The inspector has not noticed and neither has the tenant contractor, so far anyways(fingers crossed.) I talked to the manufacturer but all they would do is tell me to contact the lic. tech.
Before this issue comes up again I am going to find out for sure. I believe I am right in thinking it needs to be coverd, but I have been wrong before.
Old 12-02-2008, 08:32 PM   #8
Ivinni's Avatar
Are you talking about firestopping the head of wall joint or fireproofing?
If it's firestop at the joint you are talking about, considering the walls are not rated, the answer to the original question is "no".
Fireproofing sparyed foam canuck Insulation 3 11-29-2009 06:59 PM
fireproofing canuck Carpentry 0 11-12-2008 05:10 PM
