Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction
Old 04-20-2009, 07:23 PM   #1
Trade: Electrical contractor
Fire Rated Pocket Door
Our architect did not realize that we need fire rated pocket doors in a bathroom that houses a gas fired furnace. Multiply this by ten apartments in a roughed in building and I have a problem.
Anyone know of a available fire rated pocket door??
Thanks.
adirusso is offline   Reply With Quote
Old 04-21-2009, 03:56 PM   #2
General Contractor
greg24k's Avatar
Why you need a fire-rated door, the bathroom will face the living space...If anything, the wall adjacent to the boiler room should be fire-rated.
Thanks.
greg24k is offline   Reply With Quote
Old 04-21-2009, 03:59 PM   #3
genecarp's Avatar
The bathroom is the boiler room.....G
genecarp is online now   Reply With Quote
Old 04-21-2009, 05:19 PM   #4
Century Man
Century Man's Avatar
Trade: interior and exterior remodeling
Send a message via Skype™ to Century Man
Thanks.
Sounds to me like the architect has a problem.
Century Man is offline   Reply With Quote
Old 04-21-2009, 06:52 PM   #5
General Contractor
greg24k's Avatar
dahhh me It went right over me Thanks!
Old 04-22-2009, 10:22 AM   #6
As much as you can, make this the architects problem.
Fact is I do not think there is such a thing as a fire rated pocket door. Fire rated doors are assemblies. They should have closers or bommer hinges to ensure that they are closed except when they are being actively used. And they often will incorporate smoke gaskets around the perimeter.
How can a closer be built into a pocket door? What kind of gasketing will work? I do not think that any manufacturer builds a affordable UL rated pocket door assembly
Anti-wingnut is offline   Reply With Quote
Old 04-22-2009, 10:26 AM   #7
LRG WoodCrafting
Leo G's Avatar
Trade: Professional Sawdust Producer
The architect will turn it into someone else's problem. How can it posibbly be the architects fault.
Measure Twice Cut Once -- It's a lot easier to cut more off then it is to cut MORON.
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline   Reply With Quote
Old 04-22-2009, 10:32 AM   #8
Well, the architect is going to have to come up with a solution. The entire wall is probably going to have to be ripped up and replaced. I do not think that a pocket door frame can be part of a fire wall assembly
Old 04-23-2009, 06:03 PM   #9
Im pretty sure you're correct the assemble would leak air. Apartments with a furnace in the bath is messing with my head too. When is that ever allowed? Perhaps an R-1 with a rated corridor. INFO is missing somewhere for sure.
tom m is online now   Reply With Quote
Old 04-23-2009, 06:28 PM   #10
Trade: building
gas fired heaters or boilers in a bathroom or bedroom need to be in a closet with weatherstripped doors and pull combustion air from outside.
catspaw is offline   Reply With Quote
Old 04-23-2009, 06:52 PM   #11
Dave from Macatawa
macatawacab's Avatar
Trade: GC, cabinet maker and remodeler
This does not add up to me either. I can't put a gas fired dryer in a bathroom only electric.
Google "UL one hour wall assemblies" and you will find 50 or more configurations but a pocket door assembly will not meet a one hour requirement.
Interesting first post question from someone not listed as remodel or builder
macatawacab is offline   Reply With Quote
Old 04-23-2009, 07:36 PM   #12
He was a drive by poster....... It sparked my interest so I replied. You can have a sealed combustion direct vent water heater if you wanted too......... but a furnace? Either way who would design such a horrible situation. The door has to be self closing and there may actually be unit that automatically draws itself to a tight close. I'm a residiential and the IBC does clarify this possibility.
Gene I like Jim much better than Neil.
Old 04-23-2009, 07:46 PM   #13
genecarp's Avatar
[quote=tom m;663888
Gene I like Jim much better than Neil.[/quote]
, Neil will hang for awhile, but your vote is noted.G
Old 04-24-2009, 06:53 AM   #14
He seems to have disappeared. He listed himself as an electrician. Why was he even concerned, unless he himself was the developer?
Depending on how the codes are interpreted, if a fire door is required, it is not too much of a stretch to think that fire dampers will/should/could be required for penetrations through the enclosing walls.
Seems like the architect, GC, mechanical contractor, and the sparky! have a problem
Old 04-24-2009, 08:40 AM   #15
Historic Housewright
Jason W's Avatar
Trade: Preservation & Reproduction Millwork
Send a message via Skype™ to Jason W
I think it could be done, but you'll need an automatic closer for the fire rated assembly to be correct. That would be costly with a pocket door.
Jason W is offline   Reply With Quote
Old 04-25-2009, 04:24 AM   #16
Exclamation Fire Rated Pocket Door
I am both an electrical contactor and developer. The design was questionable from the beginning but I had the archtect put in writing that a fire rated door was not required back in August of last year when I thought that the design was questionable, and now he has made a 180 degree turn and said that it is required. So it is definitely a problem that will required some major work. he has offered his E & O insurance to cover the costs but i never made a claim on that type of policy before and I can assume that the cost of repair will be substantial.
Hence my post.
Old 04-25-2009, 04:26 AM   #17
Type of Furnace
By the way it is a sealed combustion, direct venting furnace/ with a coil for the Ac condenser.
Old 04-25-2009, 08:04 AM   #18
Dave from Macatawa
Adirusso - you need to post your location. I know code for three states but maybe not where you are.
An architect made a mistake, did a 180, and now offers E&O? Two out of three sound right.
The Following User Says Thank You to macatawacab For This Useful Post:
adirusso (04-25-2009)
Old 04-25-2009, 10:12 AM   #19
This project is in NYC
This project is in New York City...
Old 04-25-2009, 10:35 AM   #20
Hmmm....So combustion is a non issue. I guess its design places continuity on a party wall or its being classified as incedental use. IBC says any furnace room with equipment of 400,000 BTU or greater needs protection. Most tankless units draw over 200k themselves. That may be why. Good luck, thats a big change order. As you know all the penetrations need special attention too.
Class 1 (or A) fire rated decking AndyJones Decks & Fencing 16 08-15-2008 09:02 AM
Retrofit Fire Door Atikokan Construction 2 03-10-2008 05:59 PM
Top mounted hangers against fire rated plywood, do studs and joists need to line up? personalt Carpentry 2 08-20-2006 03:24 PM
Door hanging Nick H Carpentry 4 02-27-2006 02:22 AM
fire rated walls toastermaker Electrical 11 01-14-2006 01:41 PM
