Finishing Basement
Old 01-08-2004, 08:31 PM   #1
NewbeeHomeowner's Avatar
Question
Finishing Basement
Near the end of building my first home, and have decided to put a bedroom, washroom, and half bath in my full basement.I need ideas with what to do with the cold concrete floor, and heating options. As for the half bath, I've been told I would need a pump system because my septic outlet is about four feet from the floor. I have a forced hot water furnace (oil) and was told to put an old cast iron radiator onto the return line. Now the floor, I've been given a couple of options. One, Put laminate down with throw rugs. Or strapping then plywood. Or Two by fours, pressure treated then plywood. But I'm conserned with water. I don't want to spend money on something that I'll have to rip out. I have a sump pump hole in one corner with a slightly slopped floor.
NewbeeHomeowner is offline
Old 01-09-2004, 06:13 AM   #2
Exclamation
Re: Finishing Basement
Posted on the wrong site. I need to slow down and read alittle. Again SORRY for posting here. Have reposted at diy. THANX
Old 01-12-2004, 08:44 PM   #3
theman's Avatar
I read your message with interest ! Did you apply and receive a building permit, If not I suggest you do so Ask the bld inspector the same question you posted he-she MIGHT have the answer
theman is offline
Finishing basement loogout1 Carpentry 14 07-01-2007 06:55 AM
Finishing Basement SHORTGUN General Discussion 1 03-11-2007 11:37 PM
Basement Finishing Hockeyman Construction 12 09-21-2006 12:03 AM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
Finishing a Basement Rough-in cblevesque Plumbing 2 08-25-2005 06:56 PM
