Face Stone On Exterior Of House
Old 04-20-2007, 03:00 PM   #1
rwhittaker's Avatar
When applying face stone to "drivit" house exterior what is the best adhesive and mortor and does it require brick ties? If so, what is the proper spacing on the ties?
rwhittaker is offline
Old 04-20-2007, 03:42 PM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Re: Face Stone On Exterior Of House
Be carefull when dealing with Dryvit walls.
In many areas, they are not permitted on wood frame structures, but are fine for concrete walls. The reason goes back to the many problems with moisture and in some cases, mold.
Make sure you have something in writing when it comes to making penetrations in the Dryvit system. - Either from designer, owner or Dryvit.
If you are applying cultured stone, the will be instructions on how to apply the stone to different surfaces. Cultured stone is considered a adhered vener by the codes and it relies on adhesion and not nails. Dryvit has been through this before, so if they should supply any technical support, they will tell you how to attach the stone.
If you end up with a typical Dryvit situation/problem, a forum opinion will get you no where in court. Dryvit has been through many, so they should know. If you have a "Dryvit" knock-off system, be very careful about the instructions.
Dick
concretemasonry is offline
Old 04-20-2007, 05:09 PM   #3
HemiMan2500HD's Avatar
Trade: masonry and general construction
If it were my project I would pill the dryvit off
HemiMan2500HD is offline
Did you see Flip this house - Cat House? SuperiorBuilt Off Topic (Non Trade) 18 01-24-2011 05:17 PM
Stone Wall Pricing CJKarl Masonry 45 01-09-2008 08:23 PM
`Flip This House' star accused of fraud AmeliaP General Discussion 28 06-03-2007 10:21 PM
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 10:09 PM
