Epoxy Basement Floor Coatings???
Old 07-24-2007, 10:21 PM   #1
kermmonk's Avatar
Trade: builder
Hello,
I am working on a new home now. Basement floors will be poured this week.
Have you guys ever used the Epoxy floor coating kits that can be purchased from the big box stores. Do they hold up? Is the old standard concrete sealer better?
Thanks,
Kermmonk
kermmonk is offline
Old 07-25-2007, 01:12 AM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Epoxy Basement Floor Coatings???
I used the HD brand Behr AcrylicEpoxy to coat some old stained exterior concrete at a friends house back in March, took two coats, seems to work, but I'm not a painter or epoxy guy. So who wants to hit me for using this product?
Chris
Chris Johnson is offline
Old 07-25-2007, 08:22 AM   #3
Frankawitz's Avatar
I have never used the Big Box stores paints, unless a customer has to have it. we have always used the two part epoxy's from BM or SW or Pittsburgh. when putting down epoxy you want to make sure the floor is dry and clean any little bit of dirt or water can screw things up, we also use have used Floor and Deck enamel for basement, Good luck there are so many products for floors now a days.
Frankawitz is offline
Old 07-26-2007, 09:02 PM   #4
kermmonk's Avatar
Trade: builder
Hey guys,
Basement was poured today. Finishers recommend I use Cure and Seal instead of epoxy. They recommended sealing within two days.
I was thinking of using the Acid stain and then the Cure and Seal over top of that. What do the experts think?
kermmonk is offline
Old 07-30-2007, 10:15 AM   #5
Team Scream's Avatar
Trade: Electrical
I did not think you were supposed to use anything over the top of acid stain
Team Scream is offline
Old 07-30-2007, 08:14 PM   #6
RJH Designs LLC's Avatar
Trade: No
Dear Kermmonk
I'm a home builder.
I found a product that I been using on my garages floor call Armorcoat. They are on ebay. Product is as advertised. Check them out.
RJH Designs LLC is offline
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
Wooden Basement? LWF Construction 21 05-08-2006 04:17 PM
Landscape solution to basement moisture problem RJC Construction 3 11-21-2005 01:34 AM
