EP&B Framing
Old 02-16-2018, 12:52 PM   #1
quantumflux's Avatar
Trade: General
Rewards Points: 164
EP&B Framing
Any opinions on EP&B framing for new construction residential (see: http://www.greenbuildingadvisor.com/...and-beam-walls )
It looks like it isn't approved in the IRC yet, so just wondering if anyone has done this, what issues they've run into with local officials , etc. If the local official made you get engineering approval how complicated/costly that is (I've only had to do it a couple of times for much smaller things).
Thanks!
quantumflux is offline
Old 02-16-2018, 07:37 PM   #2
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,302
Re: EP&B Framing
Thanks!
Educate us a bit. GBA makes you put in payment info for a free trial, after taking your email address.
Golden view is online now
Old 02-16-2018, 07:45 PM   #3
edward trowelhands
Trade: Diplomat
Re: EP&B Framing
Did a little reading.
I did lots of similar walls in Alaska. I wonder if this calcs out less for shear? I see the sheathing has twice as many and longer nails.
Generally this type of wall requires a more carefully detailed vapor barrier. 6mil with tremco seams and sealed boxes and penetrations. In the PNW where kraft faced or even no face and just PVA primer acting as the vapor barrier, I could see dew point and condensation issues at the foam plane happening. Would require education and then additional labor to do a better vapor barrier.
SmallTownGuy (02-17-2018)
Old 02-16-2018, 10:01 PM   #4
Trade: General
Rewards Points: 164
Re: EP&B Framing
The following link has a bit more info, including vapor barrier strategies (start page 35)
Old 02-16-2018, 10:01 PM   #5
Trade: General
Rewards Points: 164
Re: EP&B Framing
Helps if I put in the link... http://summit.eeba.org/data/energyme...etter-Wall.pdf
The Following User Says Thank You to quantumflux For This Useful Post:
Old 02-17-2018, 11:09 AM   #6
Trade: General
Rewards Points: 164
Re: EP&B Framing
Actually here is the construction guide that is mentioned in the presentation I linked to earlier:
http://www.homeinnovation.com/~/medi...l%20System.pdf
Anyone on here built these yet? Thoughts?
Framing Costs Per Sq. Ft. clexteriors Framing 20 09-26-2014 08:04 PM
Traditional Framing a threat to National Security Dustincoc Framing 43 08-19-2013 10:41 AM
Framing shop drawings mikecocozza Commercial Construction 21 09-28-2012 11:22 PM
Steel Framing Fasteners Orca Construction 12 05-23-2009 07:25 AM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 05:11 PM
