Engineered Floor Joists.......
Old 01-07-2007, 05:10 PM   #1
LEVELBEST's Avatar
Trade: Contractor, Trim Dude, and Custom Cabinet Maker
I have a client whos' father says that the ply section of the engineered floor joists is nothing more than particle board and when exposed to a damp crawlspace or other moistures it will just fall apart like cardboard. Anyone have any info or links to info that will tell him differently?
Thank
L
LEVELBEST is offline
Old 01-07-2007, 05:37 PM   #2
mdshunk's Avatar
Re: Engineered Floor Joists.......
Well, it's not particle board. It's OSB.
If the crawlspace is excessively damp enough to cause OSB to delaminate, that entire home is unfit to live in.
That's my two cents... sorry, I don't have any links to offfer. What I can say is that there's so much resin in the web of I-Joists, I don't see how water would effect them very much. That's just my opinion.
mdshunk is offline
Old 01-07-2007, 06:40 PM   #3
Thom
thom's Avatar
Level, I think your clients father is one of those who thinks he knows everything and anything new (at least less than 50 years old) is crap.
The web is OSB. If you've ever seen OSB that has weathered, it holds up well. The engineered joists hold up better than dimension (which is what he's probably pushing for). Dimension has knots that seriously effect its integrity. If you've been doing this awhile, you've seen broken joists and rafters resulting from knots. Dimension crowns, twists, warps, and breaks. I've used both a lot. Engineered is way better in my opinion.
thom is online now
Engineered wood flooring installation graart Flooring 10 08-07-2007 08:52 PM
Engineered Floor Installation BoydS Flooring 4 02-17-2007 07:18 PM
engineered hardwood wildeman Flooring 5 10-06-2006 08:06 AM
Engineered studs? RYANINMICHIGAN Framing 7 03-22-2006 05:28 PM
Has anyone used Supress (sound engineered )Drywall icg0405 Drywall 0 02-15-2006 01:31 PM
