Trade: remodel and finish
Drain Tile Question
does anyone install foundation drain tile around a monolithic slab on grade foundation or a shallow footer/wall/ slab on grade foundation where freeze/thaw is not going to happen. i'm talking about a filled raised lot in southern florida.
thanks |
Trade: underground
Re: Drain Tile Question
Provided soils are well drained, I can't imagine what puprose drain tile might serve in tropical climates.
Fortunately I keep my feathers numbered for...for just such an emergency. -Foghorn Leghorn |
any more i do as a mater of course. been through enough 8" eave overhang copled with sprinkler systems that wash home owners houses opposed to sprinkling their lawns to recognise climes below the masion dixion get enough rain to float a slab, crack brick walls and generally create havoc with deluge and drought senarios on southern biulding code slabs.
you have enough rain, or a sprinkler system capable of floating a concrete floor slab, you have more problems than a little drain tile will help.
someday, i'll be as patient as Nick. |
Vagitarian
There is no need for a drain tile system. Even if you have footers and there is no crawlspace or full basement and the foundation will be filled with a slab ontop, you still don't need a drain.
| Condensate drain question | airwick | HVAC | 6 | 07-23-2007 07:48 PM |
| French drain question | 72chevy4x4 | Construction | 4 | 11-01-2006 10:46 PM |
| tile prep question | ch0mpie | Flooring | 17 | 10-03-2006 05:29 PM |
| Tile Design Question - Borders and Multiroom | Jason | Ceramic & Stone Tile | 3 | 07-24-2006 04:32 PM |
| Backsplash Tile Question | Robie | Remodeling | 5 | 02-13-2006 09:32 AM |
