Dowell For New Slab To Old.
Old 08-12-2006, 04:48 AM   #1
415moto's Avatar
Trade: General contractor
What is the desired depth to drill for reinforcing a new slab to an old slab, to join via rebar?
Any input or opnions on this. Hole size, depth, favorite epoxy, amount of dowells, spacing, etc.
415moto is offline
Old 08-14-2006, 02:07 AM   #2
415moto's Avatar
Re: Dowell For New Slab To Old.
anyone?
415moto is offline
Old 08-14-2006, 03:27 AM   #3
Spectatorz's Avatar
Trade: Ca. General
Thumbs up
I am willing to throw my opinion into the matter here...
The minimum rebar should be of #4 grade (1/2")
The Depth should be At Least 6-10" imbedment into existing concrete
with a Minimum of 24" into the new concrete to tie in
and I would advise using Simpson Epoxy ET-22
Depending on the length of slab to tie together, I would put a bar (Dowel) at every 2-3 ft to ensure a good Strong Tie in.
For what it might be worth... Good Luck
Good Luck
"Success" Is The Ability To Go From Failure To Failure,
Without Losing Your ENTHUSIASM.
The Only Place that Success comes Before Work is in The Dictionary.
Spectatorz is offline
Old 08-14-2006, 05:43 AM   #4
joasis's Avatar
A little more info would be helpful, and what is going to be on this slab, etc.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 08-14-2006, 06:55 AM   #5
PipeGuy's Avatar
Trade: underground
'Typical' overlap at splices is 30 x the diameter of the bar.
PipeGuy is offline
Old 08-14-2006, 08:37 PM   #6
415moto's Avatar
thanks for the info.
any and more opinions or directions to a specific code/shart/regulation would be also great.
in my particular case, this was for a landing being extended 12 inches, (yeah thats it). so it went from being 7 feet from the house to 8 feet.
about 12 inches thick which was depth of old slab. The cement guys doweled every 12-14 inches a long the face of the slab, 6 inches deep, set with a 2 part hilti brand epoxy. exposed bar was 8 inches into the new 12 inch slab. Its outside and not a living space. Not load bearing, strictly cosmetic.
In either case, when new things I havent seen befire are done, I like to read up and get as much info as I can on it.
415moto is offline
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
built up slab question stampcrete Concrete & Paving 9 03-27-2008 05:24 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
Fiber reinforced slab cost in central NJ gschotland Masonry 0 11-18-2006 02:27 PM
Basement slab question n74tg Masonry 5 05-26-2006 04:38 PM
