Dormer
Old 12-21-2017, 07:01 PM   #21
Tom M's Avatar
Rewards Points: 3,558
Re: Dormer
I personally would triple the outer rafters too. I think the rule of double rafters is over used to a negative.
Tom M is online now
wladd77 (12-21-2017)
Old 12-21-2017, 07:23 PM   #22
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 850
Re: Dormer
The doubled up rafters will have to carry the load of the header and the header is now carrying the load of part of the original roof and at least half of the new gable dormer roof all transferred to two points on the exterior wall and to a lesser degree to the main ridge board and to the rafters on the opposite side of the ridge board. Plus, now the header is carrying a point load in its center from the gable ridge.
The connections for all of this have to be designed also. Seems a bit dicey to me.
Andy.
ScipioAfricanus is online now
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
Old 12-21-2017, 07:35 PM   #23
B.Johnson's Avatar
Trade: Builder
Rewards Points: 430
Re: Dormer
Not arguing with you Andy, but I have a question.
I thought that roof loads are calculated by their horizontal spans. If that's true then there would be less load on the ridge, as some of the load is carried by the dormer ridge to the outside wall.
I do agree that there may be point load issues, but I do not possess the brain power to address them.
Home Designer Series Software
B.Johnson is offline
Old 12-21-2017, 07:38 PM   #24
FrankSmith's Avatar
Rewards Points: 4,132
Re: Dormer
If I am trying to size lumber for something like this and an architect isn't involved I call my lumberyards supplier. They will run the numbers for the exact lumber I will be using and tell me sizes and how many to carry the load. They even give me a print out for the building department. That would be a great option if your lumber yards supplier has such a service.
FrankSmith is offline
The Following User Says Thank You to FrankSmith For This Useful Post:
Old 12-21-2017, 08:38 PM   #25
hdavis's Avatar
Rewards Points: 3,417
Re: Dormer
And this is one reason why you should have an engineer walk you through this.
Edit - sorry B Johnson, I was in a hurry and thought this was from the OP...
hdavis is online now
Old 12-21-2017, 08:57 PM   #26
JAH's Avatar
Trade: carpenter
Rewards Points: 1,780
Re: Dormer
If you are using LVL's for rafters your plans will require a stamp. Bring your prints to a SE and have them stamp or mod the plan.
JAH is offline
The Following User Says Thank You to JAH For This Useful Post:
Old 12-21-2017, 09:08 PM   #27
B.Johnson's Avatar
Trade: Builder
Rewards Points: 430
Re: Dormer
No problem, I never want to stop learning.
The Following User Says Thank You to B.Johnson For This Useful Post:
hdavis (12-21-2017)
Old 12-21-2017, 10:09 PM   #28
wladd77's Avatar
Trade: Builder
Rewards Points: 44
Re: Dormer
I'm not an engineer....
I say as long as your doubles are strong enough to carry the load you should be fine. Personally I would triple them. Obviously your floor is going to keep the rafters from spreading and if it can't spread it can't come down. You will also need to support the dormer ridge at the gable wall. If you want to post a link to your .plan file I'll see if I can fix the overhang in front of the dormer for you. I'm certainly no expert, but you might need to change the wall type directly below the dormer to high shed wall type or you should be able to edit that section of the roof directly.
Thank you, that's my thinking as well, but I've sent an email to the engineer regardless. Hopefully, he's not on vacation yet.
Not sure how to post a link to the .plan file?
wladd77 is offline
Old 12-21-2017, 10:12 PM   #29
wladd77's Avatar
Trade: Builder
Rewards Points: 44
Re: Dormer
That's a great idea. I'll check with them. I use National Lumber in Newton.
wladd77 is offline
Old 12-21-2017, 10:34 PM   #30
hdavis's Avatar
Re: Dormer
It's also possible to have custom trusses made to HANDLE this, depending on whether they would interfere with your celing plans. The truss company does the engineering.
Old 12-22-2017, 12:07 AM   #31
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 228
Send a message via Skype™ to jlhaslip
Re: Dormer
Since it is a Timber Frame building, you might want to find an Engineer familiar with TF structures.
HERE is the website address for the Timber Framers Guild. There are a ton of them in the NE part of the country, many with in-house Engineering services.
They will be more familiar with designing connections and routing Load Paths, etc through the frame than a typical SE, IMHO.
jlhaslip is online now
The Following User Says Thank You to jlhaslip For This Useful Post:
Seven-Delta-FortyOne (12-22-2017)
Old 01-07-2018, 08:45 AM   #32
Pro something
M.F Custom's Avatar
Trade: Construction
Rewards Points: 176
Re: Dormer
Plan looks good to me, I've done that style dormer with the same framing details with no problems...
M.F Custom is offline
Building Shed Dormer / Design bmbcontracting Architecture & Design 0 07-25-2017 05:39 PM
Shed vs Gabled dormer GeeJay Architecture & Design 2 01-17-2014 06:35 PM
Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer sbebuilders Framing 33 04-18-2013 06:29 PM
The proper way to flash a stucco dormer? mastersplinter Roofing 2 03-25-2013 01:08 PM
Adding a Dormer: Design/layout mc handyman Finish Carpentry 9 10-21-2011 02:22 PM
