Dormer
Old 12-21-2017, 08:34 AM   #1
wladd77's Avatar
Trade: Builder
Rewards Points: 44
Dormer
Hi folks, I'm new to the trade and looking for some advice...
I'm remodeling the second floor of my barn and want to put in a 15' wide gable dormer. My question is, do I need to replace the existing ridge beam with a structural ridge?
The new dormer won't reach the existing ridge. We were going to run a double header joist hung from double LVL's rafters down the sides. The gable end will sit on the outside wall.
Here's a drawing...
wladd77 is offline
Old 12-21-2017, 09:01 AM   #2
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 854
Re: Dormer
Your Trade is "Builder" is it?
Andy.
ScipioAfricanus is offline
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
hdavis (12-21-2017)
Old 12-21-2017, 09:17 AM   #3
hdavis's Avatar
Rewards Points: 3,439
Re: Dormer
Assuming you want to build this to code, my advice is to read the IRC on this topic.
hdavis is online now
Old 12-21-2017, 10:04 AM   #4
wladd77's Avatar
Trade: Builder
Rewards Points: 44
Re: Dormer
Andy.
Yes, but as I said I'm fairly new to the biz. I've built single window dog house dormers that only required doubling the rafters and adding a header. I've built smaller shed dormers that used collar ties to tie into the other side of the roof. I've done wide shed dormers that required a structural ridge. But I've never done a wide gable dormer like this. I thought someone here might have experience with it.
wladd77 is offline
The Following User Says Thank You to wladd77 For This Useful Post:
SmallTownGuy (12-21-2017)
Old 12-21-2017, 10:36 AM   #5
wladd77's Avatar
Trade: Builder
Rewards Points: 44
Re: Dormer
I do want to do it to code and there is a permit on this project, although this dormer was not part of the original plan.
I have tried to find answers for this question in the code book, but am coming up empty. I like to use an online version because it lets you search for terms but it only kicks back 3 answers to the word "dormer." Two of the answers are about energy efficiency and the other one is just a definition.
Under the roof construction section (802), there's all the standard info on tables on rafters and spans. There's a section on "Roof Openings" (802.9) that I thought might apply, but it's just a paragraph and all it says is if the header joist span exceeds 4 ft, the trimmer joists and header joist have to be doubled and strong enough to support the ceiling joists and framing into the header. That's all well and good but there's nothing about how that may or may not affect the existing ridge. I feel like I must be missing something, but I can't find the answer in the book either.
Again, hoping a more experienced contractor has an easy answer...
"No, a gable dormer, no matter the size, doesn't effect the ridge beam. It's headed off and the doubled rafters at the sides carry the load to the outside wall."
"Yes, a gable dormer that big will effect your ridge beam, the doubled rafters carry the load to the outside wall but there will still be uneven pressure from snow loads on the other side so best to get an engineer to size a new ridge..."
wladd77 is offline
The Following 2 Users Say Thank You to wladd77 For This Useful Post:
Rio (12-21-2017), SmallTownGuy (12-21-2017)
Old 12-21-2017, 10:38 AM   #6
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 290
Re: Dormer
Am sure there is a few guys here that have done those. But the thing is there is a lot of home owners trying to pass as contractors coming here asking how to do things. Not saying this is the case with you. When a new guy comes here and posts a question like this with out any real introduction and involvement with the guys here. Well most guys are a little reluctant to give out information. Become part of the group and it is easier to get help or advise.
Randy Bush is online now
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
ScipioAfricanus (12-21-2017), wladd77 (12-21-2017)
Old 12-21-2017, 10:43 AM   #7
wladd77's Avatar
Trade: Builder
Rewards Points: 44
Re: Dormer
Thanks for that explanation. I was wondering why I got the responses I did, but i wanted to be respectful in my responses since I'm new. I've read posts here in the past but I could usually find the answers to my questions by searching so I never felt the need to sign up. This was a question I couldn't find an answer to online so I signed up today and posted this. I will go to the introduction thread and say hello.
wladd77 is offline
The Following 5 Users Say Thank You to wladd77 For This Useful Post:
Frank Castle (12-21-2017), hdavis (12-21-2017), Randy Bush (12-21-2017), WBailey1041 (12-21-2017), Xtrememtnbiker (12-21-2017)
Old 12-21-2017, 10:43 AM   #8
Designer/Contractor
Rio's Avatar
Rewards Points: 416
Re: Dormer
Nice model, think it will be okay but that is definitely not a full throated 'go for it' endorsement.
Rio is offline
The Following User Says Thank You to Rio For This Useful Post:
Old 12-21-2017, 11:16 AM   #9
hdavis's Avatar
Re: Dormer
The first thing to do is figure out if it already has a structural ridge. The second thing to do is review the applicable code. Searching for dormer when you have a question about the ridge isn't going to get you there.
Old 12-21-2017, 11:46 AM   #10
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 7,230
Re: Dormer
"adding dormer to existing"
https://www.google.com/search?q=addi...w=1366&bih=662
Net Zero Energy Is Here Now
“The worst day working for yourself, is still better than the best day working for someone else!”
..Jim Rohn
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 12-21-2017, 11:46 AM   #11
hdavis's Avatar
Re: Dormer
With no other information, I'd just be inclined to put a matching dormer on the other side. It avoids the question of asymmetric loads, plus putting a 50ft engineered beam into the top of a barn isn't as much fun as it sounds.
The first thing my engineer would if tasked with making stamped plans is inspect the existing structure. If you don't know what you're seeing, you can't really do that yourself.
Old 12-21-2017, 01:05 PM   #12
wladd77's Avatar
Trade: Builder
Rewards Points: 44
Re: Dormer
Thanks. It's from a software called Home Designer Pro by Chief architect. Very easy to use for floor plans and quick mock-ups. But it would take some time to really master the program. For example, I can't figure out how to take out the little cripple rafters in front of the dormer. On the real one, I'd like the soffits to stop at the dormer so the siding can run up the face of the dormer.
It's not a structural dormer. Just a 1x8. I'll search the code book for ridge beam and see if that helps.
Originally Posted by SmallTownGuy View Post
I spent about 4 hours looking up variations of "Dormer addition" on Google last night, though I didn't try that specific wording. I took a quick look at the results before posting this and it looks like more of the same. Anything wider than 6' is a shed dormer which I've done but don't want to do on this project. I'll give those results a longer look at lunch. Thanks.
wladd77 is offline
Old 12-21-2017, 01:08 PM   #13
wladd77's Avatar
Trade: Builder
Rewards Points: 44
Re: Dormer
Yeah, that would definitely work but we were hoping to keep the other side clear for solar panels at some point. The other side faces south and is completely clear of obstructions so it's a good spot for it. I still have to do a lot of research on that. I've never done solar panels, but I did ask the electrician to run a pipe up there so if we do decide to add it we'll be able to pull a wire through without having to open up walls or have a conduit on the outside.
wladd77 is offline
Old 12-21-2017, 01:37 PM   #14
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,710
Re: Dormer
I have plenty of gaps in my knowledge. I've tried to do it all, and the trade-off is that, while I'm never bored, I scratch my head a little more than I wish.
And this is why I have an engineer. I draw something up, and run it by him. Sometimes it's really simple, but I just want that second opinion. Had to call him the day before yesterday about a little mishap, and an exceptable way to fix it. 5 minutes on the phone.
Delta
I have an Edifice Complex.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
hdavis (12-21-2017), Tom M (12-21-2017), wladd77 (12-21-2017)
Old 12-21-2017, 02:06 PM   #15
hdavis's Avatar
Re: Dormer
OK, You're going to have trouble if you don't have the terms right. You can either be talking about a ridge board (which a 240 yo barn may not even have that) or a beam for a structural ridge. A board is 1x material. Search for ridge, and it will cover both. I think It's somewhere around 8.07, but don't quote me.
You also didn't mention what type of framing this has. If It's 240 yo, I'd expect post and beam framing.
The short story on this is you compare the roof system to current code. Almost all are underbuilt by today's standards. You now are responsible for making changes to a substandard roof system. That takes judgement in evaluating.
If you really want to just have the one dormer, have an engineer stamp a solution. $300-500 well spent.
JMO.
Old 12-21-2017, 03:12 PM   #16
wladd77's Avatar
Trade: Builder
Rewards Points: 44
Re: Dormer
JMO.
Yes thank you, it's a ridge board, and the barn is post and beam framing. We dug under the posts to put in new footings and poured a curb around the perimeter. The roof is made of 2x6's that are 24" o.c. which is undersized for the span. We planned on splitting the bays with new 2x6's to make the roof framing 12" o.c. which pushes it well into the green as far as carrying the load over that span.
I'll take a look in the book for ridge boards/beams. 807 is attic access and 806 is roof ventilation, but I'll see what I can dig up. If I come up empty again, the engineer is my next move.
wladd77 is offline
Old 12-21-2017, 05:35 PM   #17
hdavis's Avatar
Re: Dormer
New construction, a structural ridge is required for slopes less than 3:12.
Section 802.2
Old 12-21-2017, 06:36 PM   #18
Eater of sins.
Rewards Points: 854
Re: Dormer
A 15' wide span for the dormer would put it beyond the prescriptive designs in the IRC. I think that getting an engineer involved in this is the prudent thing to do.
Being as you are in MA. you have snow loads and wind loads to consider, well the engineer has to consider those loads.
Andy.
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
Old 12-21-2017, 06:55 PM   #19
B.Johnson's Avatar
Trade: Builder
Rewards Points: 460
Re: Dormer
I'm not an engineer....
I say as long as your doubles are strong enough to carry the load you should be fine. Personally I would triple them. Obviously your floor is going to keep the rafters from spreading and if it can't spread it can't come down. You will also need to support the dormer ridge at the gable wall. If you want to post a link to your .plan file I'll see if I can fix the overhang in front of the dormer for you. I'm certainly no expert, but you might need to change the wall type directly below the dormer to high shed wall type or you should be able to edit that section of the roof directly.
Home Designer Series Software
B.Johnson is online now
The Following User Says Thank You to B.Johnson For This Useful Post:
Old 12-21-2017, 06:59 PM   #20
Tom M's Avatar
Rewards Points: 3,576
Re: Dormer
Typically you would double the ridge due to unequal loading. Give the proximity of the header and lateral support of the gable I think it's fine.
Or I should say, I think the SI would agree.
Tom M is online now
Building Shed Dormer / Design bmbcontracting Architecture & Design 0 07-25-2017 05:39 PM
Shed vs Gabled dormer GeeJay Architecture & Design 2 01-17-2014 06:35 PM
Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer sbebuilders Framing 33 04-18-2013 06:29 PM
The proper way to flash a stucco dormer? mastersplinter Roofing 2 03-25-2013 01:08 PM
Adding a Dormer: Design/layout mc handyman Finish Carpentry 9 10-21-2011 02:22 PM
